Author Topic: Whats diff between a Dana 60 and 8 3/4 rear end?  (Read 2219 times)
Offline uthustler
« on: February 09, 2008 - 08:37:00 PM »
Can someone share some differences in these 2 rear ends? thanks
Offline 426HEMI
Re: Whats diff between a Dana 60 and 8 3/4 rear end?
« Reply #1 on: February 09, 2008 - 08:47:22 PM »
the main two differences is weight and strength.  Dana is heavier and stronger in the long run.  It is according to what you are running and if you have an automatic and stick.   :feedback:
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline uthustler
« Reply #2 on: February 09, 2008 - 08:51:40 PM »
guy is running a 440-6, figured it would have a dana behind it, but has the 8 3/4.
Offline 426HEMI
« Reply #3 on: February 09, 2008 - 09:00:31 PM »
They usually had the 8 3/4 behind them.  When the car was ordered it could have been upgraded to a Dana.  The 440-6 I had was an 8 3/4 also.  They are strong enough to hold up behind the 440-6.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
Offline FJ5_440
  • Wisconsin
« Reply #4 on: February 09, 2008 - 09:41:18 PM »
the 440-6 autos had the 8 3/4  the 440-6 4-speed cars had the Dana.  the 8 3/4 will take serious power, but the Dana will take more for longer.
** Shane **
« Reply #5 on: February 10, 2008 - 05:24:05 AM »
There's A HUGE difference in price too.  :money:
« Reply #6 on: February 10, 2008 - 06:41:28 PM »
actually no by the time you buy all the good parts for an 8 3/4 diff you can get a Dana for a very similar $$$
Offline hemi71
« Reply #7 on: February 11, 2008 - 05:26:29 PM »
8 3/4 has a carrier that loads from the front of the housing. You can pull the center section out and rebuild it outside of the car. The Dana 60 has a rear cover plate and the ring gear/pinion loads from the rear. The 8 3/4 is a lot easier to change axle ratios, just drop in a different center section.
All RB 4 speed E bodies came equipped with a Dana 60 as mandatory. RB autos had 8 3/4's as standard equipment. You could pay the $$ and get a Dana 60 as an optional rear.
Dana 60's are pretty bullit proof, but on a street car that does not see a lot of track use with slicks, an 8 3/4 will hold up fine. The tires act as a fuse, too much torque applied and the tires will blow off before the rear grenades. Now apply some traction and torque levels above 500 lbs/ft or so...better invest in the Dana.
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #8 on: February 11, 2008 - 08:23:37 PM »
Only if it came with the standard 3:23's. If it was ordered with an axle pkg it would have been a Dana.
2013 Tige' RZR 343hp
Offline hemi71
« Reply #9 on: February 11, 2008 - 09:14:52 PM »
also, with the 3.23's without the SG...you got a 22 inch radiator
« Last Edit: February 11, 2008 - 09:18:08 PM by hemi71 »
