Author Topic: Rust Bullet or POR 15 inside the frames  (Read 1900 times)
« on: February 09, 2008 - 10:27:28 PM »
Anyone know of a way to get a good amount of spray of either POR or Rust Bullet inside the frames? I would like to get the back half frames a good coat inside.
My car is on a rotisserie.
Offline Chlngrcrzy
Re: Rust Bullet or POR 15 inside the frames
« Reply #1 on: February 09, 2008 - 10:47:28 PM »
 :popcorn: Great idea. I will be watching this one too. Hope somebody has some info.
Offline farmboy70
« Reply #2 on: February 09, 2008 - 10:54:23 PM »
For enclosed areas you can get a rocker shutz gun and modify a tube similar to a under coating kit. These have a spray end attached to spray a fan. Just slide it in a access hole and pull back out as you spray.
 A good auto body suppy store should have a inexpensive under coat spray kit. You could also fabricate a end to do this also.
Offline R/T hedkace
« Reply #3 on: February 09, 2008 - 11:07:56 PM »
 That's pretty good to know Dave. Never thought of anything like that  :cheers:
 Another good thing that I found works just as good is to Completely remove your trunk floor, and any other panel that may be in your way, ( even if they're not rusty, take em out anyways. It will save you a ton of time in the long run  :roflsmiley: ..........J/K
 But it was pretty convenient for me  :woo:
 Actually, I'd just listen to Dave if I was you  :grinyes:
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
« Reply #4 on: February 09, 2008 - 11:11:46 PM »
Thanks Dave for the heads up. I'll pay them a visit on Monday then to get what I need. I already did the trunk rails while the floor was out.
« Reply #5 on: February 09, 2008 - 11:25:06 PM »
« Reply #6 on: February 09, 2008 - 11:28:12 PM »
And use this too?
Ever try this stuff or should I stick with using the POR?
https://www.autobodytoolmart.com/p-14348-4150-3m-rust-fighter-i-08891.aspx
Offline farmboy70
« Reply #7 on: February 09, 2008 - 11:30:41 PM »
Ahaaa!!! This must be the critter I need.
https://www.autobodytoolmart.com/p-14347-4648-3m-rust-fighter-i-application-wand-08998.aspx
Yep thats the wand I was talking about , the gun is listed on that page also.
Offline farmboy70
« Reply #8 on: February 09, 2008 - 11:32:14 PM »
And use this too?
That product is for replacing the rust protection on a repaired panel. I would use the POR or Rustbullit to kill the rust that is already there myself.
« Reply #9 on: February 09, 2008 - 11:50:38 PM »
Great I'm buying the wand, gun, and Rust Bullet right away,
Offline farmboy70
« Reply #10 on: February 10, 2008 - 12:06:23 AM »
 :2thumbs:
Offline dougs bs23
« Reply #11 on: February 15, 2008 - 03:22:45 PM »
you can pick up a shutz gun for around 20 dollars at eastwood,  also there rust encapsulator and to undercoat everything else spray on bedliner,  I used there gator gaurd II A little messy but with some prep masking and in a "tent "worked very well.
http://www.eastwoodco.com/
« Reply #12 on: February 15, 2008 - 05:32:03 PM »
Hemiken just helped me out today with one I bought on e bag. It had the wand and the gun for 15 bucks. Kenny sent him the MO to the seller for me and then I paid him. Thanks again Kenny.  :2thumbs:
Offline hemiken
« Reply #13 on: February 15, 2008 - 07:39:19 PM »
 :clapping: More than happy to help out a fellow C-C.Com brother. :wave:
Offline RUSTY Cuda
  • One big step foward!
« Reply #14 on: February 15, 2008 - 09:25:56 PM »
I used the eastwood one with por 15, messy but effective!
I just used a plain old piece of 3/8" tubing to extend the rod to get all the way into the rockers & long frame rails. Rich.
