Author Topic: Am I the only one who hates air shocks?  (Read 1926 times)
Offline mikerallye
« on: February 10, 2008 - 09:32:09 PM »
Just took off a set of air shocks from my rallye. They are harsh and make threatening sounds. Is it just me or is the the best that the engineering would can come up with? Does anyone have any suggestion on how to raise the rear about 2 inches without the negative attributes of air.    :villagers:
Offline GoodysGotaCuda
Re: Am I the only one who hates air shocks?
« Reply #1 on: February 10, 2008 - 09:43:25 PM »
Springs rearched, super stock leaf springs or another aftermarket increased lift/hd spring. I have taken a set of air shocks off my car, only reason i bought them was to clear my old tires off the 1/4 until i could buy my super stock springs.
1976 Dodge Warlock
Wheel & Tire Specs:Link
« Reply #2 on: February 10, 2008 - 10:22:22 PM »
Gabrial high jackers...coil spring assit :bigsmile:  Still old school though :2thumbs:
Offline BIGSHCLUNK
« Reply #3 on: February 10, 2008 - 10:26:03 PM »
NIKKI"S got the XHD ones (leaf springs)thru MP. That booty sits just fine!  :bigsmile:
IMO Air  shocks are band aids for bad springs.  :grinyes:
« Last Edit: February 11, 2008 - 09:20:06 AM by BIGSHCLUNK »
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline bb71challenger
« Reply #4 on: February 10, 2008 - 10:40:52 PM »
NIKKI"S got the XHD ones thru MP. That booty sits just fine!  :bigsmile:
 :iagree: That is the reason I had them on my car to begin with. Well and putting 295/50/15's on the back too. I will let my car sit low in the back before I put those air shocks back on. I plan on getting xhd springs or ss springs before I get my car all back together. As a sad note, my car goes back into the shop this April but still will not get color until the fall  :'(  The contractor is way behind on adding on to the place. Maybe by next summer I will have it back together and running down the highway.  :dunno:
*Brett*
Offline DAYTONA
« Reply #5 on: February 10, 2008 - 10:58:37 PM »
...I had Hi-Jackers on my CUDA 35 years ago....I honestly didn't know they were still on the market :roflsmiley:
Offline 71340RT
« Reply #6 on: February 10, 2008 - 11:13:47 PM »
I had air shocks back in the 70's and think they shuld not even be allowed to be put on cars. The bumps are bad with them and they make your car handle real bad in corners. I wanted my Cuda and Challenger a little higher than stock so I had ESPO make me a set just like the TA and AAR cars which are 1 inch over stock. Best change I ever made and the ride is great and I love the ride height.
70 Plymouth Cuda 340 4-speed
2003 Dodge Stratus RT coupe
2014 Ram Express 5.7 Hemi 4X4
Offline DAYTONA
« Reply #7 on: February 10, 2008 - 11:18:57 PM »
...I agree, they were dangerous....the car handled terrible
...I ran a set of Mickey Thompson M50 tires on the back and the Hi-Jackers were the only way to make it happen....110lbs did the job
« Reply #8 on: February 11, 2008 - 01:40:03 AM »
I Hate both Air shocks & Load leveler type coil over shocks , both put excessive pressure on the shock crossmember which is a bad way to do things & coil overs set up an ocillation in the rear that will bounce the rear tires under hard launch
the best way to raise the car is re-arcing the springs or adding leafs , you can also modify the ride height a little with the front spring eye mounts
« Reply #9 on: February 11, 2008 - 09:10:04 AM »
Another 70's way was longer rear shackles. Oh the memories. But I don't suggest this method either.
I am with Chryco on his last statement.   So I have the one last 80's style suggestion for the poor man. I used to do this all the time.
I'd get 1" longer ubolts and a new center pin. Go and buy some 3/4 truck springs. They had a bigger arch. I kept the factory top e body main spring and then used a long truck spring after that, and staggered it just one inch from the front hanger. Then the 3rd spring was stock e body, the 4th was truck , keeping the stagger in front 1" shorter each time. Then the rest was stock e body under that like normal. So I ended up running 8 on the left and 9 on the passenger side. It raised the ride height, made it ridgid, and helped launch the car. I reclamped the front springs together, And left the back unclamped.
So old school ways was
1  air shocks
2  coil helpers
3  longer rear shackles
4  Adding leafs
Re-arching and or adding springs is a good sure way to achieve your goals
Offline matt63
« Reply #10 on: February 11, 2008 - 10:15:04 AM »
I've got air shocks until I get some new springs (2" over stock).  The air shocks are crap and they were not even that cheap.
Matt in Edmonton
'68 Valiant
Offline Scatterbrain
  • 1973 Challenger
« Reply #11 on: February 11, 2008 - 10:42:29 AM »
I've also got air shocks and hate the ride.  So I can get the same kind of height from 2" longer leaf's ?  I've got big tires that would hit without the air shocks, but would love to get rid of them.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #12 on: February 11, 2008 - 12:55:02 PM »
I have air shocks on the rear, but I am only running 5 psi.  Rides okay for me.
« Reply #13 on: February 11, 2008 - 01:00:54 PM »
Longer, no. More arch, yes.
Offline ChallengerHK
« Reply #14 on: February 11, 2008 - 01:45:05 PM »
About 30 years ago my boss' son put airshoks on his Camaro and then had one blow out in a hard turn. Car flipped and went roof-first into a telephone pole, and the kid was getting rehabbed for a year. Ever since, I avoid air shocks  :eek4:
- Han Solo, Star Wars
