Author Topic: Am I the only one who hates air shocks?  (Read 1924 times)
Offline vinb
Re: Am I the only one who hates air shocks?
« Reply #15 on: February 11, 2008 - 04:05:57 PM »
The only thing air shocks do is crack the welds on the ends of the shock crossmember and shakes everything loose........ :o
Offline mikerallye
« Reply #16 on: February 11, 2008 - 08:12:55 PM »
Does anyone know how to re arch the springs? I have  never discovered a way to weld spring steel, but apparently there is a way to heat it and bend it in a safe and reliable manner. thanks
Offline challenger470
« Reply #17 on: February 11, 2008 - 08:58:40 PM »
yes I hate air shocks
Offline Goehner
  • 392 IE
« Reply #18 on: February 11, 2008 - 11:28:33 PM »
When I bought my first car, a 74 Road Runner, it had 6 or 8" shackles on it. It was disgusting!! Tore em off and had the springs rearched. Much better ride. A good suspension shop can rearch them and even add an inch or two to the ride height this way. Much cheaper than putting up with the shackles and/or air shocks. I have to admit, it was kind of fun with the air shocks bouncing around with 100 psi in em, prolly not safe, but I was 16, didn't really care, just wanted to put  5 people in my car with HUGE tires in the back and I cringed when the tires rubbed.
392 Edition on order
08 Mega Cab 3500 SRW 6.7 CTD, 2" Leveling kit, 33" Mickey Thompson MTZ
05 Durango Limited, Yea, it's got a HEMI!!
« Reply #19 on: February 12, 2008 - 07:13:22 AM »
No easy way to do it at home as it involves lots a heat and tension that has to be controlled through out the arching process.  Plus a leaf spring is too big to fit into the oven.
Offline Ross
« Reply #20 on: February 12, 2008 - 03:00:23 PM »
It sounds like the guy that I bought my challenger from was quite the guy back in the day... :crazy:
I've got Hi-jackers, 10" shackles (that he had to butcher the rear valance to "fit".  Oh and of course the classic white axle/differential
These are the first parts to be replaced once the body is done!
'70 340 Challenger
A whole lot of rust and very little time to work on it...
