72hemi, that is some absolutely great news for my ears. With my arthritus pains dominating me on twisting wrenches on my back, you may have save me some major work
My trans used to go into reverse when I got it. I had installed the shifter and linkage while it was out to make all the adjustments on it before I installed it. Then after I had installed the trans and put gear oil in it, I noticed I had leaks, so I pulled the cover off and sealed it and it hasnt worked since. Maybe , just maybe I have the same problem
and it will be a breeze for me.
Thank you for sharing that info..........
