Author Topic: Anyone tried these yet from XV ?  (Read 931 times)
Offline Confederate Cuda
« on: February 11, 2008 - 08:15:27 PM »
Thinking about buying these. Has anyone tried them??
Offline hemiken
Re: Anyone tried these yet from XV ?
« Reply #1 on: February 11, 2008 - 08:17:55 PM »
How much is this kit ?
« Reply #2 on: February 11, 2008 - 08:20:57 PM »
I think the front and rears are $1000. Not cheap but I have not heard of another good option.
Offline hemiken
« Reply #3 on: February 11, 2008 - 08:22:43 PM »
 :22yikes:  Thanks.................i think :faint:
Offline miketyler
    • www.miketyler.net
« Reply #4 on: February 16, 2008 - 10:13:05 AM »
man, they have got to be good products if made by XV.  However, I installed the Electric Life set in my car a couple years ago. They bolted right in and were reversing style so was able to use OEM switches so all looked factory. Still around $250 US
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
« Reply #5 on: February 16, 2008 - 01:21:29 PM »
What did you do about the 1/4 windows and also do your windows go up slow??
Offline miketyler
    • www.miketyler.net
« Reply #6 on: February 16, 2008 - 03:05:50 PM »
I haven't done the 1/4 windows yet, was probably gonna use the Calibri universal setup although I was looking for other solutions. The Calibri utilizes the existing regulator. It motorizes the door handle shaft. If I understand correctly,  when installed you have to  put a cap over the shaft that protrudes out from the door panel. Not too keen on that. :eek4:  When I do find the right product, I have the OEM 4way master switch and two single switches when I get around to it.
On the main windows, they do not roll up as fast as they go down. They are affective and roll down faster than you could crank them by hand. I thought about welding lugs on the scissors and adding a helper spring. The modified assembly would load up on the way down slowing the downward speed and would unwind on the way up increasing up speed. Careful spring selection and attach points along the lever would be critical. I would probably try and dupe the originals. The original regulators did have springs, didn't they?
« Last Edit: February 18, 2008 - 06:57:14 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
