Author Topic: shifter mechanism  (Read 964 times)
Offline Mopar Junkie
  • I'm a llama!
shifter mechanism
« on: February 17, 2004 - 08:53:12 PM »
Hi guys, my question for today is, are the B body pistol grip shifter mechanisms the same as the E-Bodies? I know that they mount further towards the front of the trans on the Bs but are the shift levers in the same location, and just use different rods than the E-Bodies? If they're not the same then under what part number and where can i get one? Thanks
Re:shifter mechanism
« Reply #1 on: February 18, 2004 - 01:33:52 AM »
yes & no , They mechaism will interchange & work but the B bodies with the long pistol have longer levers in the shifter mechanism & shorter levers on the tranny to shorten the throw as much as possible
 The shifter can be bought new from Hurst as a Hurst Competition +
  • I'm a llama!
« Reply #2 on: February 18, 2004 - 05:46:16 AM »
Cool, thanks for the info. I will check out the comp shifter.
Offline matt63
Re: shifter mechanism
« Reply #3 on: July 02, 2005 - 08:27:28 PM »
I have a Cuda project with no shifter, shifter mounting plate, levers or rods.  If I buy the Hurst Competition Shifter, what levers should I buy? (E body or b body)?
Thanks,
Matt in Edmonton
Matt in Edmonton
'68 Valiant
« Reply #4 on: July 03, 2005 - 12:40:18 AM »
I would use the double hole E body ones & use the hole nearest the pivot hole to shorten the shift
