Can the body line shift ???
Author Topic: Can the body line shift ???  (Read 984 times)
Offline Confederate Cuda
« on: February 12, 2008 - 11:18:34 PM »
My car is currently on a rotisserie and we are sanding it, is it possible for the body line to shift once is has weight on it? My guess is no but I thought I would ask.
Offline elitecustombody
  • Supra collector
Re: Can the body line shift ???
« Reply #1 on: February 12, 2008 - 11:50:36 PM »
are you talking about a bodyline/crease on a quarter panel shifting and getting out of alignment with a door or fender? yes it's possible
Stefan B
« Reply #2 on: February 12, 2008 - 11:52:57 PM »
Most cars I see posted on a rotis, have an x brace on both sides of the door jams and top
« Reply #3 on: February 13, 2008 - 09:00:45 AM »
So I guess I should spray the underside and then set the car down and finish blocking it??
Offline RUSTY Cuda
  • One big step foward!
« Reply #4 on: February 13, 2008 - 09:05:45 AM »
YES! I lined up my doors (off the rotis) but on jackstands(at the lift points) when I put it back on the wheels the rear of the door dropped almost a 1/2" . Rich.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #5 on: February 13, 2008 - 09:09:02 AM »
Yes!
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
« Reply #6 on: February 13, 2008 - 02:24:42 PM »
Wow, 1/2 inch, I can't imagine that. Is the weight distribution that much different?? I sure hope that I don't have the same issue but will put it on the wheels to make sure. My car also has frame connectors so I hope that will stiffen it as well.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #7 on: February 17, 2008 - 07:28:31 AM »
i put 20lbs in the doors to act as the glass and stuff to help keep the gaps and lines correct.
Go Fast & Have Fun...
Offline ksierens
    • 70 Challenger Resurrection
« Reply #8 on: February 17, 2008 - 09:13:01 AM »
My car is currently still on the rotisserie.  I am going to paint the bottom and engine compartment, then get it back on the ground, including the engine and trans, and then do the finish body work.
Kurt - SE Michigan
Offline 426HEMI
« Reply #9 on: February 17, 2008 - 09:37:54 AM »
These cars will flex or bend more than most think.  I remember a lot of the cuda's and challengers I had you could hear them pop every time you turned a corner.  The doors are a big part of the body.  There is not as much support as you think.  Be Careful when using the rotiseries.  Put in braces in the openings for the doors if they are off.   You can even bend them on a swing arm rack.  Make sure the doors are closed when lifting them.
1970 M46 Barracuda
1998 Dodge Darango
Gordon
