Author Topic: Painting Torsion Bars?  (Read 4425 times)
Offline ChallengerHK
« on: February 13, 2008 - 09:12:53 AM »
I've been painting (with POR-15) everything that goes back on the Challenger's suspension. Any reason to not paint the t-bars? Obviously I don't want to paint the hex ends, but everything else?
- Han Solo, Star Wars
Re: Painting Torsion Bars?
« Reply #1 on: February 13, 2008 - 09:32:21 AM »
Yes paint em. The originals were dipped in paint and had drippys hanging.
Offline farmboy70
« Reply #2 on: February 13, 2008 - 09:34:00 AM »
No problem doing them that way.
They should be dipped if you are going OEM, with drips and runs. Don't forget the identifier stripes also.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #3 on: February 13, 2008 - 11:11:54 AM »
POR-15 is very hard, I wonder if it will crack when you put a load on the bars?   :clueless:
Kurt - SE Michigan
« Reply #4 on: February 13, 2008 - 11:41:20 AM »
Good; they'll fit with my sway bars  :lol2:
That's one of the things I was wondering about. Worse comes to worse, I'll redo them later. On the other hand, I noticed that, at least with the grey POR-15, it has a lot of flex to it, so maybe it'll be OK.
« Reply #5 on: February 13, 2008 - 11:41:54 PM »
could powder coat them also , you can paint the hex ends as well the factory did
« Reply #6 on: February 14, 2008 - 12:47:18 AM »
Thats what I did so mine. They look like they were dipped in a dark purple liquid mercury.
Offline duodec
« Reply #7 on: February 14, 2008 - 02:02:58 AM »
Ever since I had a torsion bar snap on my '71 I've wondered if there was a good quality more protective coating; I don't know if it would have saved mine (I think it got gouged by a piece of cinderblock I couldn't avoid because it broke a few minutes later, thankfully in a parking lot!).  I wonder if the spiral plastic wrap, or the longitudinally slit corrugated tube made for wiring could be used to cover the exposed section of the bar to protect it from road hazards.  Neither should interfere with the twisting motion needed.
It sounded like a rifle shot; most impressive!
Offline Kapteenikosmos
« Reply #8 on: February 14, 2008 - 03:10:44 AM »
Actually por 15 is far from hard eventhough the website says it is. There is no way that it would break on torquebars because of the stretching. The structure of the paint is more like latex than anything else. I had some adhesion problems on new sheet metal I had welded to the floor and I literally pulled out the paint with my fingers from a large area.
So I would say that por 15 would be an excellent choice for seasoned torquebars because it likes to adhere to surfaces like that and It can definately handle some serious stretching.
Ville
1967 six banger Mustang
1973 Challenger (under restoration)
1997 Lincoln Mark VIII LSC (daily driver)
Offline troutstreamnm
« Reply #9 on: February 14, 2008 - 11:07:50 PM »
POR-15 works great on torsion bars as well as the rest of the suspension.  It is a great protective paint, yet flexible.  I've had in on my Charger for several years now with now cracking or flaking.   :thumbsup:  The entire suspension on my Challenger is now coated in POR-15
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
« Reply #10 on: February 15, 2008 - 09:02:43 AM »
Thanks for the info, guys.
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #11 on: February 18, 2008 - 05:14:49 PM »
I am having the new ones i am installing in my car powedercoated. They will never have a problem then.
« Reply #12 on: February 18, 2008 - 09:46:15 PM »
When you get them done, tell the powder coating guy to leave them over night to cool down slowly in the oven. Sometimes they pull stuff out hot. I don't think that would be good for them. Not sure. Thats just a pre caution I did with mine just in case.
