Author Topic: SAFETY STUFF  (Read 1616 times)
Offline BIG MIKE
SAFETY STUFF
« on: February 18, 2004 - 03:45:22 AM »
never weld galvanized metal it makes a  poisonous gas
« Last Edit: February 18, 2004 - 03:46:27 AM by BIG MIKE »
Offline mustardketchup
  • I'm a llama!
Re:SAFETY STUFF
« Reply #1 on: February 20, 2004 - 05:07:42 PM »
Big Mike:
     Can't you grind off the galvanized area where you are going to lay your bead and then weld?  It's a good idea to be outside in the fresh air, though.
Larry
Offline BIG MIKE
Re:SAFETY STUFF
« Reply #2 on: February 21, 2004 - 12:01:38 AM »
the only way i would weld it is with a fresh air system and outside. i don't think grinding will get it off, or that's what i heard.....
lemonboy69
Re:SAFETY STUFF
« Reply #3 on: February 21, 2004 - 12:10:58 AM »
Don't weld rubber... errr.. umm... wait, that doesn't work... unless you're BIG MIKE welding your tires to the ground!! :D ;D ;D ;D
Thanks for the heads up... I'd heard that somewhere too... ::)
LB
Offline 1973challenger360
Re:SAFETY STUFF
« Reply #4 on: February 21, 2004 - 03:34:07 AM »
galvanized can be spot welded, but I dont recomend inhaling the fumes.  with the claw looking spot welder.
