Author Topic: Master Cylinder Gasket  (Read 971 times)
Offline troutstreamnm
« on: February 14, 2008 - 11:15:07 PM »
Is there a gasket between the master cylinder and the power brake booster?  I have a paint kit with a gasket that fits perfectly in that area, but the service manual shows no pics or discusses one in the assembly text.  Thanks
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
Re: Master Cylinder Gasket
« Reply #1 on: February 16, 2008 - 02:21:36 AM »
nto usually , the 4 bolt gasket would go against the firewall with std brakes though
« Reply #2 on: February 16, 2008 - 08:45:16 AM »
Thanks Chryco.  The gasket kit must cover all basis so this is an extra one for me.  Appreaciate the clarification
Trout
08 SRT-8 Challenger
71 GA4 Challenger
70 FK5 Charger 500
« Reply #3 on: February 16, 2008 - 10:40:09 AM »
the kits generally cover all posibilities so yes it would be for manual brakes , I couldn`t see the pic last night but can now
Offline vinb
« Reply #4 on: February 17, 2008 - 06:24:18 PM »
Looking at the photo, if its a foam gasket it would not be a bad idea to keep it on just in case the cylinder leaks one day and will not remove the paint , if its a plastic one don't use it because it will change the depth of the booster push rod and screw things up...
« Last Edit: February 18, 2008 - 09:14:18 PM by vinb »
