Author Topic: 70 440 stock manifolds  (Read 1446 times)
bbscamp
« on: February 15, 2008 - 10:57:13 PM »
Are the 440 stock HP exhaust manifolds for 1970 the same as the 69 B body ones offered by YO?
see:  http://www.yearone.com/pco/1_0907/full.asp?page=260   I don't care about the casting numbers....but is the fit the same?  how close?
Re: 70 440 stock manifolds
« Reply #1 on: February 15, 2008 - 11:47:33 PM »
If you look at the yearone picture guide for the exhaust exit, the flange on one pipe will not fit the stock e body exhaust pipe is it. It is turned on a different angle. But it will work if you make your own pipe or turn the flange and reweld on the existing e body pipe. It will fit on the engine and up into the engine bay just fine. Been there and done that :2thumbs:
bbscamp
« Reply #2 on: February 16, 2008 - 09:29:53 AM »
what are the correct casting numbers for a 70 BB e-body?
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #3 on: February 17, 2008 - 05:04:15 PM »
I have a pair of e body big block HP manifolds, drivers side cast date of 4/71 , passengerside dated 11/70. Email me if interested. They have been sand blasted and painted. Heat cross over valve is intact and working.
bbscamp
« Reply #4 on: February 20, 2008 - 02:56:57 PM »
I'm going with a 440 in the 70 challenger, so I need to get the exhaust castings to match the rest of the exhaust, I'm not concerned about them being "70" casting numbers
I found out the 1970 RH casting is 2899879.   (The LH casting as 2951865;  I have one of those)
The RH 2899879 is B/E for 70-71.   Books also show 3751071 correct for "B" cars for 73-74.  (no E's had 383/440s after 71) I have a 3751071.
Now the question is:  is the RH 2899879 the same as  RH 3751071?   if so....I'm set.
Offline ksierens
    • 70 Challenger Resurrection
« Reply #5 on: February 20, 2008 - 03:28:54 PM »
... or if you buy the exhaust from TTI, you can tell them what manifolds you are using and they will send the correct pipes.
Kurt - SE Michigan
« Reply #6 on: February 20, 2008 - 04:08:36 PM »
I think mine say 865 lft and 879 rt hard to read them
Offline RusTy/SE
  • Just havin' fun
« Reply #7 on: February 20, 2008 - 04:17:19 PM »
Those are the correct numbers Al :thumbsup:
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
