Author Topic: Clutch Pedal Bracket & Pin  (Read 685 times)
Offline vinb
« on: February 16, 2008 - 10:38:58 PM »
Hey guys, I'm getting closer to gathering up all the parts I need to convert to a 4spd.
1. My question is do I need the clutch pedal bracket pn #3467203 it mounts on the left side of the main support bracket and both pins go thru, or can I get away without it. If so does anyone have one for sale or do you know where I can get one.
2.  The 4spd I picked up the case numbers are 0E11778 / PP8333009 / 0136 / 3 / C99129H. I guess its a '70 trans but is it a early or late. Would like to know so I can figure out the ratios..
 Thanks..............
Re: Clutch Pedal Bracket & Pin
« Reply #1 on: February 18, 2008 - 02:01:53 AM »
yes you need the support bracket , from either Brewers or PG classics
Offline vinb
« Reply #2 on: February 18, 2008 - 05:42:25 PM »
Thanks CP, I kind of figured that because the car I took it out of was missing the spring and the clutch pedal bushing was worn pretty good. I called Brewer & PG , they will not sell it seperate. Must buy the whole kit for $200. I really don't need the pedals and the other stuff. I have time I'll just keep looking for one maybe someone on the board has one to sell..
I looked in the parts book and B-body uses the same bracket. original #3467203...
also need the short pin..
