Author Topic: Wire harness #2983712  (Read 2572 times)
Offline ArcticCuda
    • Pepe
« on: February 17, 2008 - 06:16:25 AM »
Where does this belongs to? Harness# 2983712 code 78352. Blue and yellow wires.
Current Vehicles:
Plymouth PPR Cuda 1970 489 cid
Plymouth GTX 1970 RS23V0E
Sorry my bad english...I'm just an european...
Offline Slotts
Re: Wire harness #2983712
« Reply #1 on: February 17, 2008 - 02:14:57 PM »
Do you have a picture of it that you could post?
Slotts
Offline JayBee
« Reply #2 on: February 17, 2008 - 04:07:33 PM »
Definately a picture or more info would help, like where is it located? I looked in my parts book under "Numeric Index" and that number didn't appear. My book did have 2983711 & 2983713, neither of which harnesses have blue and yellow wires. The more info you give the more people may be able to help, not too many people have parts book.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline dutch
« Reply #3 on: February 17, 2008 - 05:28:39 PM »
the only thing I can come up with would be wiring for the cruise control . those are blue and yellow if I remember correctly. Pictures would make things easier though...
*** Bart ***
Offline ArcticCuda
    • Pepe
« Reply #4 on: February 18, 2008 - 02:27:24 AM »
Correct, that number is missing from parts book.
Those wires are coming from dash board. I think that they go to overhead console. Blue is for low fuel, yellow for seat belt warning light.
Current Vehicles:
Offline JayBee
« Reply #5 on: February 18, 2008 - 04:57:34 PM »
After looking in my service manual it does show a connector with a dark blue and yellow wire located what looks to be behind the drivers side lower kick panel and it is related to the overhead console. Does your connector look like a rectangle with a triangle, sorry about my poor description. Is a pic possible?
John
2014 Toyota Avalon
Offline ArcticCuda
    • Pepe
« Reply #6 on: February 19, 2008 - 01:20:14 PM »
Wires from roof console = female plug
Wires from dash = male separate wires
Current Vehicles:
Offline JayBee
« Reply #7 on: February 19, 2008 - 05:41:49 PM »
It looks to me that the 2 separate wires were pulled out from a matching male connector for that female connector. From my "Accessory Wiring Diagram" it looks like the DBL from the female connects to the DBL w/tracer (your separate one) which comes from something called "Low Fuel Relay". The yellows connect to each other which says "Consolette and Title Lamp". Hope some of this helps. Maybe someone with a Gran Coupe would be more helpful.
John
2014 Toyota Avalon
