Author Topic: Building a 500/400 F.F.E. with Mega-Squirt  (Read 44399 times)
Offline airfueleddie
Re: Building a 500/400 F.F.E. with Mega-Squirt
« Reply #120 on: October 21, 2008 - 12:16:50 PM »
Milodon Truck pan
« Reply #121 on: October 21, 2008 - 12:20:06 PM »
Victor intake. You can also see I need to drive that transmission input shaft bushing in a little further. :biggrin:
Offline ShelbyDogg
« Reply #122 on: October 21, 2008 - 05:28:30 PM »
Wow, That oil pan is not Power Tour friendly. You should have gone with a drag race dragster type pan with the internal baffles. That thing is going to be an inch off of the ground.
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
« Reply #123 on: October 24, 2008 - 02:04:24 AM »
:iagree:   Why such a large pan?
Offline ntstlgl1970
  • T a c o c a t
« Reply #124 on: October 24, 2008 - 02:34:40 AM »
 :iagree: with what everyone else said, so this is going in a truck?
« Reply #125 on: October 28, 2008 - 10:51:51 AM »
 Standard oil pan wont fit a truck chassis. Wish I had another E-Body. It's going into a 1988 Dodge Truck for tuning on the chassis dyno, then sold after it's tuned and tested. More pics of the bottom end. I had to use a carbide cutter on the girdle for clearance to the pickup tube.
« Last Edit: October 28, 2008 - 11:09:51 AM by airfueleddie »
« Reply #126 on: October 28, 2008 - 10:56:20 AM »
Here is the cut I had to make. I radiused the cut after to prevent gouging the tube. I also will have to 'window' the windage tray in order to attach the front tube support to the #2 main cap fastener. I feel this fastener necessary to give support to the long tube and prevent cracking from harmonics and vibration. I really dont want to braze the threads as suggested so I used ARP thread sealant on the pickup tube threads,(Sparingly).
« Reply #127 on: October 28, 2008 - 10:57:56 AM »
another
« Reply #128 on: October 28, 2008 - 10:59:38 AM »
I also had to bend the pickup tube carefully to gain the necessary clearance for the girdle&Windage tray.
« Reply #129 on: October 28, 2008 - 11:08:21 AM »
As of now, I'm completely out of Money,(much like our banks&govt.)lol, so it will be the 1st of the year before anymore parts are purchased. Just wanted you dudes to know, thanks for the feedback, keep it coming. I will purchase next, 50 lb./hr/ Delphi Injectors, 4hole T.B., Walbro/Bosch fuel pump, Scott Brown sourced Hydraulic roller, I decided to use a no maintenance fast rate of lift Hyd. roller around .550 lift and 290 duration.(Maybe a Cam Motion or Crane), Mild yes, but I'm not building a drag engine either. Street Hi-Po. It will be much easier to establish a baseline with a mild cam. And of course 440 source heads. Thanks again for advice Chryco!
« Reply #130 on: November 25, 2008 - 05:45:56 AM »
Dipstick assembly. Bottom end complete
« Reply #131 on: December 04, 2008 - 12:02:02 PM »
I ordered 440 source heads today.
« Reply #132 on: December 11, 2008 - 11:13:46 AM »
Recieved the heads
« Reply #133 on: December 11, 2008 - 11:15:15 AM »
I hope I have better luck than this Sprint car head! :biggrin:
« Reply #134 on: December 11, 2008 - 11:19:44 AM »
I noticed that the valve tip on this one particular valve was chamfered or radiused a bit more than the rest. It doesnt matter, because I am only using the castings, guides. The valvetrain will ALL be speced by  Scott Brown. Scott is gonna supply me with a whole hydraulic roller valvetrain, with Manley valves, Hyd. roller springs, Cam ground to his specs, Smith Bros. pushrods, stainless bushed rockers, ect.. But the heads look great! A great buy for the money!
