I am building a 500" Low deck with a sonic tested thick wall 400 block. The mains have been honed, block decked, lifters bores lightly honed, Fixture bored and honed with torque plates, 4.375 final size with proper RA finish for Moly rings, A bought a stroker kit that has a K-1,(Carillo) 4340 Crank& H-Beam 4340 Rods, 2618 forged Keith Black Pistons. This will be a street engine first and foremost, internal oiling, no ring supports,(but it's very close!!), probably 10.5-11.0 to 1 compression with alloy heads,(I havent got that far yet, but am looking hard at the 440source heads), I already have set of beautiful 440MAX 17-4 stainless steel bronze bushed rockers with thick wall shafts and H.D. holddowns with ARP studs in 1.6 ratio factory offset so the Eddies rpm's or 440 source is the way to go. I would probably use a solid cam,,(specs unknown at this time), the oil through lifters are interesting, I wonder how the low speed oil pressure would hold up? The oil holes are 16x .019 so would this affect the low speed oil pressure? I am going to use coated bearings,(full groove Calico), H.V MoPar Oil Pump. I am picking up the machined block and stroker kit at the Indy MoPar trade Show this march 1 at the Marsh pavillion fairgrounds. Hope it's not as cold as last year. It was blowing snow and 28 out. I will include pics as I recieve them. Oh I am saving the best for last but I am going to inject this thing and use a MegaSquirt II P.C.M. to control it.
