When you get to the point of completing the EDIS wiring, make sure to duplicate the factory shielding (wires wrapped in foil) for the CKP, IDM and Spout wiring.
Yeah, thanks Nostalgia70, I have the EDIS module already and the SPOUT,(Spark output), and VR Sensor wires are shielded to reduce IMF/EMF voltage potentials in other wiring sensitive to such 'spikes', I'll do just that, appreciate the suggestion. I think I had a 'moment' of clarity while under my diesel truck. I think the master wiring connector goes to the PCM and then to the relay board. The main harness wiring would go to the relay board screw in wire 'pins' and they gave me the wiring bundle for that already and I have the pigtails to the coolant sensor, and the IAC sensor, I guess I was thinking too much into it. BTW, Chryco, this is the 'easy' setup for mega -squirt systems. You can buy the individual components down to the mother board and build your own PCM. The setup I bought is the most 'user friendly' setup you could possibly get. Also note guys, Mega-Squirt, Micro-Squirt,(fuel control only), are very reasonably priced. I got my entire pre-assembled PCM, EDIS module, ECT/IATsensors, coded wiring, Main harness connector, stim, relay board, all for under 1k. The MS is also an educational/experimental system. The other systems mentioned above are all over 3k!! Some high end systems are over 6k!(Stack Hilborn MPI)(Motec) ect,, with a MS you could probably build your own setup for under 500.00 if you wanted to start from scratch and hit the salvage yards.
