Author Topic: Building a 500/400 F.F.E. with Mega-Squirt  (Read 44395 times)
Re: Building a 500/400 F.F.E. with Mega-Squirt
« Reply #165 on: March 01, 2010 - 02:04:08 AM »
been there done that too
Offline airfueleddie
« Reply #166 on: March 19, 2010 - 01:27:32 PM »
I should have asked your advice before I started this Roller deal Chryco!! :sly: :grinyes:Here's what I had to do. The rear welch plug is obviously installed. To check the proper thrust clearance I had to grind then radius the cam button a bit, repeated trips to the sioux grinding machine to remove .010 at a time then mock it up and  check it. After 7 times I had the required clearance which is easier to hear it tap the inside of the cover than to feel for .010 with a large screwdriver against the cam lobe taking care not to scratch a lobe. Clay helps to get a baseline, if the cover wont go on at all then the button will have to be either changed to a different style or it will have to be severly ground, some buttons wont allow this like the Diamond,, a Crane/Comp alluminum will work ,,I havent tried the Nylon which might actually be a better choice depending on the type of cover you decide to use.
« Reply #167 on: March 22, 2010 - 11:10:37 PM »
#1
« Reply #168 on: March 22, 2010 - 11:12:39 PM »
#2 PAC Ovate wire valve spring kit sourced by Scotty Brown
Offline Tubbed440
  • Suspension NinJa
« Reply #169 on: March 26, 2010 - 02:14:55 PM »
Are you planning on going with the Ford EDIS-8, or are you keeping the distributor and running a crank trigger?
74 Dodge Challenger
500 inch stroker, Full cage, ladder bars,
coil-overs, 4L80E, 325/50 M/T DR's....street car!
(work in progress)
« Reply #170 on: March 27, 2010 - 09:00:10 AM »
I along with 2 other builders are still waiting for the Engine Dyno and assembly lab here at school. We were promised this 'Lab' 2 years ago and was the primary reason whi I enrolled in Auto Tech,,if not for that I would be in Machine Instrument Tech.(Machine Shop). Since I have no control over any of their aquisitions, I gotta 'go with the flow',,so I want to complete this with a standard distributor and E-85 Carb, pay out of pocket to get it dynoed here in town at Eric Bonwells Racing Engines and Cylinder head machining Service($375.00 for 4 pulls), post those results and go from there. But I still have the complete EDIS-8.
« Reply #171 on: April 05, 2010 - 10:05:30 AM »
Part#72338LUN  Lunati's newly released B/RB Hyd. Roller Lifters
« Reply #172 on: April 05, 2010 - 11:52:17 PM »
Assembling heads
« Reply #173 on: April 06, 2010 - 11:56:35 AM »
looks great , I like the lifters  :2thumbs:
« Reply #174 on: April 06, 2010 - 01:22:49 PM »
Thanks Chryco! And thanks a bunch for the advice too! I'll post a pic of the Lifters in their locations as soon as I get a chance OK. :thumbsup:
« Reply #175 on: April 06, 2010 - 01:26:30 PM »
I also tested each seat,(Intake&Exhaust), for 25" with a Goodson/Sioux 1730EL vacum gauge, they all held just fine. I spent considerable time making sure the seats were fine and they lapped out perfectly.
Offline ragtopdodge
« Reply #176 on: April 15, 2010 - 11:17:46 AM »
So what's your overall impression of these 440source heads?
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #177 on: April 15, 2010 - 03:57:45 PM »
For the money they are good heads. The valves are decent but everything else other than the valves and 'bare' heads should be replaced with stronger higher quality parts. I mocked up one side for the high school kids who seem to trust me. :dunno: :biggrin:
« Last Edit: April 15, 2010 - 04:02:03 PM by airfueleddie »
« Reply #178 on: April 15, 2010 - 04:00:43 PM »
another
Offline challydust
« Reply #179 on: April 15, 2010 - 05:05:26 PM »
Can somebody move that stupid motor out of the way so  I can drool over that unbelievable challenger in the backround...OMG....eddie that car is unreal...I know you have sent me pics...but that thing looks sooooo good in that pic....LOVE it bro.....Hey i made it here!!!....this forum looks super cool....Glad to be here....
