Author Topic: wheel size  (Read 2559 times)
Offline mopower
wheel size
« on: February 17, 2008 - 07:10:56 PM »
does anyone no the largest size wheel i can fit on the rear of my 73 challenger,without changing anything ? any help would be great.. thank you much
Offline 6packCuda
Re: wheel size
« Reply #1 on: February 17, 2008 - 09:22:47 PM »
You might be able to get an 8.5" in there. I don't know, I have 15x8s on the back of my Cuda and there's not much extra space on either side.
Offline GoodysGotaCuda
Re: wheel size
« Reply #2 on: February 17, 2008 - 09:28:01 PM »
18x9s on the back of my cuda with no mods but super stock leaf springs.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline mopower
Re: wheel size
« Reply #3 on: February 18, 2008 - 08:22:37 AM »
thank you much guys, i appreciate the help....
Offline drewcrane
Re: wheel size
« Reply #4 on: February 20, 2008 - 12:55:00 PM »
what size tire in the rear? and what are you running on the front?
Offline Jacksboys
  • Here Since 08/28/06 GEORGIA
Re: wheel size
« Reply #5 on: February 20, 2008 - 01:56:56 PM »
Look here:
http://www.goodysgotacuda.com/Suspension_Specs.html
Offline drewcrane
Re: wheel size
« Reply #6 on: February 20, 2008 - 07:05:08 PM »
thanks ,i have a wilwood front hub ,i wonder ?, i digress i obviously can put 18 x 9 ,s in the rear  but will they clear the fenders? hub shouldn be a problem , thanks for the link that helps alot, knowing someone else has done it, btw is there a pic of his line lock set up sounds trick thanks again :bigsmile:
Re: wheel size
« Reply #7 on: February 20, 2008 - 07:25:14 PM »
Thanks for posting the link. Not sure on the wilwood hubs, but they do fit fine on my car. As far as body changes between cuda/challenger may dictate if they will run on your ride or not.
Line lock? Sorry, no handy picture at the moment, i should add one to the site!
1976 Dodge Warlock
Re: wheel size
« Reply #8 on: February 20, 2008 - 07:31:44 PM »
Took a pic for ya. I have in-line tubing stainless steel lines, lightly tweaked it over to meet up to the line lock solenoid. Then bent up a pre-flared line from NAPA over to the rubber line's stock location.
Oh and Tire Patch anyone?  :naughty: :dogpile:
1976 Dodge Warlock
Offline drewcrane
Re: wheel size
« Reply #9 on: February 21, 2008 - 07:40:05 AM »
nice , nice ,nice thanks im copying you so you can pat yourself on the back now , i like the location :iagree:
Re: wheel size
« Reply #10 on: February 21, 2008 - 09:33:43 AM »
Keep this in mind as well. You could probably put an 11" wide wheel under the rear of a stock E body, but tire sidewall bulge creates an intereference point that is a bigger concern than the actual wheel width.
Offline drewcrane
Re: wheel size
« Reply #11 on: February 25, 2008 - 07:35:27 AM »
as the car bounces , and turns tire rub will occur ,what is the least amount of space needed for tires in the outer quarter , as well as the leaf spring on the inside,1/2 inch?
Re: wheel size
« Reply #12 on: February 25, 2008 - 10:01:39 AM »
I've run them as tight as a 1/4 of an inch to the leaf spring. Since the leafs move up and down with the tire through road irregularities, and is somewhat removed from sidewall flex during cornering, I never had any contact issues there. Spacing to the wheel lip and inner wheel well need to be bigger because of the same suspension articulation. The amount of space needed there would depend on how widely you exercise the suspension. Low sitting cars that have to traverse bumps and driveways at an angle may need more room than a higher sitting car that can go over things straight up. At these points, 1/2 to 1 inch is probably closer to the norm to avoid contact. But again, we get back to that whole "how big is the sidewall bulge" issue as well as how hard do you use it.
« Last Edit: February 25, 2008 - 01:33:13 PM by HP2 »
Offline drewcrane
Re: wheel size
« Reply #13 on: February 26, 2008 - 05:29:21 PM »
wow 1/4 inch,thats close,with a 15 inch tire yea your right , that tire will bulge a little more than say a 17,or 18 in wheel/tire, humm you make very good points and i will use them thanks again! :wow:
