Author Topic: crate hemi sharker hood cuda master cylinder /booster  (Read 1030 times)
Offline vryfast
  • WORK IN PROGRESS
« on: February 17, 2008 - 07:21:11 PM »
looking for a master cylinder/ booster that will fit a 70 cuda with crate hemi and shaker hood have disc / drum setup for brakes. can any one suggest a setup that will fit and who sells it thanks :jumping: :swaying: :crazy:
Re: crate hemi sharker hood cuda master cylinder /booster
« Reply #1 on: February 17, 2008 - 07:40:18 PM »
I just purchased a bendix Hemi booster in Dec. so I just went thru all this and what it took to do it.
If you can find an original Bendix brake booster with the offset bracket is the most ideal and correct looking set up. There's one on e bag right now but it's way out there at $960.00+. However, it is complete.
http://cgi.ebay.com/ebaymotors/Mopar-1970-71-426Hemi-Bendix-Brake-Booster-Brackets_W0QQitemZ270211054275QQcmdZViewItem?hash=item270211054275
Look at this one. Notice the studs on the back. 3/8ths and offset. This is what you need to spot for the right one. But you also need the offset bracket set up and re inforcement plate to complete everything.
http://cgi.ebay.com/ebaymotors/MOPAR-BENDIX-POWER-BRAKE-BOOSTER-CHARGER-GTX-HEMI_W0QQitemZ350025192136QQcmdZViewItem?hash=item350025192136
The next alternative is to get one of the reproduction take offs. Anotherwards, they don't even look factory correct but they should clear the DS valve cover corner. Look at the picture of the brake booster.
http://cgi.ebay.com/ebaymotors/Mopar-B-E-Body-Brake-Booster-Master-Cylinder-Prop-Valve_W0QQitemZ220201098360QQcmdZViewItem?hash=item220201098360
I don't know enough on these take offs so ask the seller questions first before you purchase one if you decide this route.
« Reply #2 on: February 17, 2008 - 07:47:47 PM »
Also one more thing to spot a real Hemi bendix brake booster, the rod coming out has a slight curve angle at the end.
Brake booster Dewey sells complete units according to his website for 900 also.
Offline vryfast
  • WORK IN PROGRESS
« Reply #3 on: February 17, 2008 - 08:32:28 PM »
topcat i don't see anything on his website about boosters
« Reply #4 on: February 17, 2008 - 08:42:02 PM »
Offline vryfast
  • WORK IN PROGRESS
Offline vryfast
  • WORK IN PROGRESS
« Reply #6 on: February 19, 2008 - 06:17:12 PM »
bought my booster and masterclyinder from doctordiff bought the front brakes and spindles off ebay now i just need to talk to inline tubes for the brake lines and i will be readty yo go mmm i mean stop :wow:
« Reply #7 on: February 19, 2008 - 09:41:38 PM »
cool.  :2thumbs:
 Did you get the Hemi Bendix? If you did, I have a question to you about the check valve. Theres a couple of different ones I need to find out more about.
