Author Topic: Auto quick shift.............  (Read 2581 times)
Offline ChallengerHK
Re: Auto quick shift.............
« Reply #15 on: February 19, 2008 - 09:41:14 PM »
Are big block and small block kick downs different? If not, I've got a small block setup you could use to test and compare if you need it, David.
- Han Solo, Star Wars
« Reply #16 on: February 20, 2008 - 05:02:12 AM »
I'm fairly certain they are different.
Offline DAYLEY/CHALLENGER
« Reply #17 on: February 25, 2008 - 11:01:48 PM »
gkring, I took your advice and put a bolt in the slot.  With the elongated slot up front, it still did not move the lever until the 4BB was about to kick in.  I now have the slot adjusted to where the lever will start to move as soon as the throttle is beginning to open. I did this tonight so I didn't take her out on the road yet.  I will give a report as soon as I do.  Thanks, David
Dave or David
Offline tactransman
« Reply #18 on: February 26, 2008 - 01:04:26 PM »
Your "pin" on the carb that the slot rides on is too far forward.It should be almost right over the carb primaries butterfly pivot shaft.
(Yellow line in second pic)
Terry-tactransman
Union, Mo.
« Reply #19 on: February 26, 2008 - 07:46:19 PM »
Thanks Terry.  I did drive the car tonight.   The bolt I put in did change the shift points a little but still shifts too quick.  I will investigate the linkage you pointed out.  I had the carb off a couple of times cleaning it and may have messed up the reassemble.  Thanks all who have answered,   David
Dave or David
Offline tactransman
« Reply #20 on: February 26, 2008 - 09:39:28 PM »
One thing to watch out for is, if you do get it shifting properly,make sure your carb is still going full open throttle and is not being stopped early by the transmission kick down linkage/lever. :thumbsup:
Terry-tactransman
Union, Mo.
