Misc Parts list
Author Topic: Misc Parts list  (Read 1690 times)
Offline KNOT0623
  • 1970 A66 Challenger
Misc Parts list
« on: February 18, 2008 - 01:40:10 PM »
I found this guy on another site...if anyone needs anything on this list...I talked to him, his name is Nate, he seems like a really nice guy. He is located near San Diego. Here ya go!!!!
 :bigsmile:
We have a resto shop and have alot of leftover original parts (used), that have acumulated around the shop. 30% off all parts. I would also like to offer the whole lot of parts, including a 20ft semi trailer that the parts are in for $9,000.00 obo, we are negotiable. There are many other parts that are not listed, for example more glass, sway bars, suspension parts, exterior trim, Cuda quarter windows(hard top and convertable, and much more '68-'69 charger parts. Sorry, no Hemi parts. Theres just too much to list. Check out the list, my # is at the end. Thanks!!
Engine Blocks
440 date 4/5/67 $750.00
c440 hp2 date 10/27/68 $750.00
c440 hp2 date 10/18/66 $500.00
d383 date 6/23/67 $250.00
400 short block (no pan) date 1/73 $325.00
Heads
part #2843906 $140.00 a pair (3 pair available)
part #3769902 $25.00
part #246516 $50.00 a pair (3 pair available)
part #2206324 $50.00 each ( 3 available)
part #3671587-7 $200.00 a pair (1 pair available)
part #2780915 $300.00 a pair (1 pair available)
part #4006457 $25.00
part $2951250 $25.00
Cranks
steel 383 standard part #2206159 $100.00
cast 400 standard part #3462923 $50.00
cast 440 standard part #3195292 $100.00 (2 available)
cast 440 standard
exhaust manifolds (all HP)
part # 2780945 $25.00 L side
part # 2951865 date 12/1/69 $150.00 L side
part # 2951865 date 11/24/69 $150.00 L side
part #2951865 date 4/21/70 and #2899879 date 3/12/70 $375.00 a pair
'70-'71 HP exhaust manifold heat shield $145.00
Carbs
Carter part #4295 '68 440 $150.00
carter part #4640 '69 440 $100.00
carter part #4966 '71 440 $150.00 carter part #4936 '70 340 manual $150.00
carter part #4133 '66 383 $75.00
carter part #4640 '69 440 $150.00
Holley part #3614140 $150.00
Thermoquad carbs
part #9097 $75.00
part #9147 $75.00
part #6321 $90.00
part #6524 $75.00
part #9150 $75.00
part #9014 $100.00
part #9054 $75.00
Intakes
part #2806178 date 12/15/67 $150.00
part #2806178 date 7/22/68 $150.00
part #2951666-1 $150.00
part #2806178 date 6/11/68 $150.00
part #3512501 date 3/2/71 $150.00
part #2806178 date 1/14/69 $150.00
part #2205000 $150.00
Valve covers B/B 4 pair ($100.00 each)
440 6 pak 908 rod and piston assembly and balancer w/ steel crank $675.00 (will seperate)
Aluminum bell housings
part #2892513-05102 BB $350.00
part #2892482 SB $100.00 (2 available)
Glass
'68-'70 charger rear window $75.00 (2 available)
'70-'74 cuda rear window $100.00 (3 available)
Misc.
'69 super bee/corenet rt quarter panel side scoops w/ crome inserts
1 needs little crack repair part #s 2902966 and 2902967 $200.00
'69 corenet finish panel $250.00
'69 corenet grill $125.00
'68 charger cpmplete grill w/ headlight vacuum motors, vacuum harness and wire harness $900.00
'68-'70 rear defroster $100.00
'70-'71 cuda/chalenger consul $175.00
'68-'70 charger upper door pads $100.00 a pair (3 available)
'68-'70 charger rear pads $100.00 a pair (3 available)
'68-'70 charger quarter panel extensions $150.00 a pair (3 available)
'69 corenet tail light assembly complete $100.00 each (1 pair +1 available)
'69-'70 charger tail light assembly complete $290.00 a pair (2 available)
‘62-72 B-body and ‘70-‘74 E-body extreme duty torsion bars. 920dia. $200.00
‘71-‘73 Roadrunner front valance (rough) $85.00
B-body 3 spoke steering wheel $100.00 (4 available)
B-body 3 spoke horn ring $30.00 (3 available)
E-body wood grain steering wheel $200.00
‘69-‘70 B-body four speed wood grain consul plate w/ rubber boot (wood grain rough) $200.00
‘68-‘70 Thumb wheel radio’s
AM+8 track $345.00
AM+FM $300.00
AM plymouth 75.00
AM dart $75.00
AM Dodge $75.00
Steering colums
‘70-‘71 Cuda colum complete w/ key AT, black wheel $300.00
‘70-‘71 Cuda colum complete floor shift, woodgrain wheel (2 cracks) $300.00
B-body black colum floor shift $150.00
B-body complete 3 spoke wheel floor shift $200.00
B-body floor shift $50.00
‘71 B-body AT $50.00
B-body complete 3 spoke wheel w/ horn pad (1 crack in wheel) $300.00
B-body complete w/ horn pad AT $100.00
Thanks for lookin! If you have any ?'s please call Nate at 951-252-3425
« Last Edit: February 18, 2008 - 01:45:07 PM by KNOT0623 »
Get in, Sit Down, Shut up and HOLD ON!!!!
1970 A66 340 Challenger 4-speed
1970 T/A Challenger 4-speed
2006 Ram 2500 Diesel
2008 BMW M3 Vert
Offline KNOT0623
Re: Misc Parts list
« Reply #1 on: February 24, 2008 - 06:17:04 PM »
Has anyone had any luck with this seller?  I just wanted to post some of his stuff.
2008 BMW M3 Vert
Offline noschevys
Re: Misc Parts list
« Reply #2 on: April 25, 2008 - 06:50:47 AM »
do you still have the valve covers?  If so can you email me some pics.
