Author Topic: Brake hold off valve.  (Read 811 times)
Offline loco440
« on: February 19, 2008 - 07:58:33 PM »
My disc brake hold off valve is leaking and drawing in air,its on a 70 Chall,for those that dont know what one is if you look under your master cylinder there are two brass blocks with brake pipes going into them,the hold off valve is the smallest of the two that recieves fluid from the proportioning valve (the big one) and splits the front brake lines,does any one know where I can purchase one of these valves?
Re: Brake hold off valve.
« Reply #1 on: February 19, 2008 - 09:15:39 PM »
http://www.inlinetube.com/ I believe has what you seek.
1970-71 E-body / 1971 B-body Hold Off Valve - Cuda / Challenger
Brass 3 Port Valve  Disc  - Part 2 of 2 for disc brakes
Brass
$89.00
« Last Edit: February 19, 2008 - 09:19:05 PM by bullitt99 »
Offline loco440
« Reply #2 on: February 20, 2008 - 04:30:00 AM »
Thanks bullitt twas the rite place,I tried to down load their car catalog to purchase the part and nothing would happen but it will open the catalog for hot rods which doesnt have the part (nothing is easy) so had to email them and just wait and see what happens.
