Author Topic: Question - Wire guage  (Read 2261 times)
Offline CUDA JAS
  • vroooooom!
« on: February 20, 2008 - 08:57:07 AM »
I am rebuilding my engine harness as most of the wires are FUBAR.
I am reusing several of the Mopar specifc connectors (voltage reg, elctronic ignition controle module, distributor).  do I need to use the same guage wire when splicing into the wires on the connectors or is it ok to upgrde to a heavier guage wire (i.e., 18 or 16 on the connector spliced to a 14)?
I will be using new connectors at the bulkhad and anywhere else that I can.
All connectionsd will be crimped and soldered.
Thanks,
Jas
74 'cuda 360/727
Just call me a gearhead!
Offline GoodysGotaCuda
Re: Question - Wire guage
« Reply #1 on: February 20, 2008 - 09:10:26 AM »
Going to a bigger gauge wire wont hurt anything. You'll have less resistance in a bigger wire over length, over a thinner gauge as well which doesn't hurt.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ViperMan
  • 2017 Carlisle or BUST...
    • JS Custom Cars
« Reply #2 on: February 20, 2008 - 12:56:17 PM »
When I redid my engine wiring I stepped everything up a gauge - doesn't hurt anything, in fact a lot of "power pinchers" will put huge gauge wires from the battery to ground and such to decrease overall resistance, supposedly boosting power to things like lights, audio, even engine spark.  I don't go that crazy with it, but it does help.
Jeff
« Reply #3 on: February 20, 2008 - 05:27:00 PM »
Those ground distributions are usually for computer controlled vehicles. And those do work actually
1976 Dodge Warlock
« Reply #4 on: February 20, 2008 - 06:16:55 PM »
What you are doing is more effort, but there is certainly nothing wrong with it.  :grinno:
Offline CUDA JAS
  • vroooooom!
« Reply #5 on: February 20, 2008 - 06:28:17 PM »
Yeah I have to rebuild the harnes because it is FUBAR..here is a pic.
My concern is that the heavier wire going into the smaller wire will create a weak spot.  Sounds like I will be good shape!
74 'cuda 360/727
« Reply #6 on: February 20, 2008 - 06:30:10 PM »
Have you tried looking for those bulkhead connection wires? I swear napa might be able to get them. Maybe email Evans Wiring if they will sell you some.
That would be nice to be able to have new, crimped/soldered connections.
1976 Dodge Warlock
« Reply #7 on: February 20, 2008 - 07:09:41 PM »
If we were talking about the interior with AC, rear defroster, power windows, or anything like that, then I would be worried about the junction between wires getting a tad warm. Thus, we are not. You only want to go bigger in the engine bay, so I see no problems. The current thru the wires should be steady as far as ignition goes. The voltage regulator wires will vary, but they just tell the alternator to step it up a tad, or not. No major current there. The biggie as far as the engine bay area is concerned is the large black wire coming from the alternator. All that current flows thru the bulkhead connector. Some have re-routed a large wire in addition to that from the alternator directly to "+" side of the battery. This may all be more than you need to know, but in doing this last step, the original amp meter won't fuction correctly as all current is no longer running thru it.  I hope I didn't lose you.  :pullinghair: It was all in the name of avoiding a melt down at the bulkhead connector.
Offline CUDA JAS
  • vroooooom!
« Reply #8 on: February 20, 2008 - 08:19:18 PM »
Nope did not lose me at all.  I will be doing the MAD amp guage by-pass well I am at.
Appreciate the info!
Goody, I have all new PED conectors for the bulkhead (MAD), but will be reusing the more specilized connectors.  So from the bulk head out will be all new.
74 'cuda 360/727
« Reply #9 on: February 20, 2008 - 08:52:46 PM »
Sounds good!
1976 Dodge Warlock
Offline ShelbyDogg
« Reply #10 on: February 24, 2008 - 01:22:16 PM »
Use an 8 guage or at least a minimum of 10 guage for the Alternator main wire. The original ones were not meant for the new bigger alternators. Connect it to a big fuse right to the starter relay or to the battery. If you go through the firewall with it, it will melt and throw sparks just like the originals did.
You can buy those snap-in female and male spade crimp-ons from any good electronics store. If you can't find them, try Digikey electronics.
« Reply #11 on: February 24, 2008 - 08:29:45 PM »
Agree with above, i actually a 100amp circuit breaker for my 90amp alternator circuit breaker which is designed for marine use. Any trouble it just 'pops'. Good maxifuse would be a good idea if not that.
1976 Dodge Warlock
