IF everything is correct in your system, pouring a little gas down your carb to get the engine almost started should do the trick. I replaced my solid fuel line from front to back. Just about the time the fuel in my fuel bowls was gone, the gas arrived from the tank.
This is a stupid question, but how did your pushrod for the fuel pump look before you shoved it up into the block? If the rod wasn't worn, you should of had to apply a little pressure to get the pump up snug enough to the block to bolt it in place.
