340 Fuelpump problems
Author Topic: 340 Fuelpump problems  (Read 9329 times)
Offline Belgium Cuda
  • Living in Belgium but beeing Swedish
Re: 340 Fuelpump problems
« Reply #30 on: February 23, 2008 - 12:37:26 PM »
 No problem with the pump, took my newly purchased vacuumpump and sucked from the carb side of the fuelhose. After that he does the work himself.
 I followed the instructions in the Don Taylor " how to rebuild Mopar small block" to get the distributor in right but will ofcourse check according
 to your advice LAA66. Also I marked everything at disassembly and it looks to be ok.  :cheers:
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
« Reply #31 on: February 24, 2008 - 06:42:01 AM »
 Now I start to doubt my engine knowledge LAA66, TDC cylinder #1 is when the piston is in the highest position and
 both valves are closed?  :feedback:
Offline LAA66
« Reply #32 on: February 24, 2008 - 10:23:59 AM »
 Yes. You can rotate the crank a bit both ways to see if there is any movement in the #1 valves. If not that should be the correct TDC.
« Reply #33 on: February 24, 2008 - 11:13:31 AM »
 I learned a lot posting this thread, the distributor was 180° wrong although I was very careful putting the engine together.
 Adjusted the valve lash according to the instructions here and engine started immediatly. thanks everybody  :2thumbs:
 Again I see the importans of asking those "stupid" questions. :cheers:
« Reply #34 on: February 24, 2008 - 12:27:49 PM »
 :2thumbs:
« Reply #35 on: February 24, 2008 - 01:29:06 PM »
 Some pictures of the newly started Cuda. I do have a problem with the steering after the change of sealings in the steeringbox
 but I will open a thread in the right department.  :bigsmile:
« Reply #36 on: February 24, 2008 - 01:30:40 PM »
 And the engine!
Offline LAA66
« Reply #37 on: February 24, 2008 - 02:05:26 PM »
 Congratulations on your motor build it looks good. :cheers:
 I have steering box seal leaks too and will follow your posts for advice.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #38 on: February 24, 2008 - 04:30:17 PM »
Great looking car!!!  :2thumbs:
« Reply #39 on: April 28, 2008 - 04:40:56 PM »
I still don't get the engine to run good under 2000 RPM, I start to suspect that the cam got damaged at start-up with all my cranking.
How do I know if that's the case? Take it out and measure?  :'(
« Reply #40 on: April 29, 2008 - 09:25:08 AM »
the engine should have a tick to it if a lobe went away , is the idle cicuit in the carb working or restricted, is the carb new or rebuilt , possibly the wrng gasket in the carb blocking the idle passages , have you removed the mixture screws & forced air or carb cleaner through the ports ?
Offline Aussie Challenger
« Reply #41 on: May 01, 2008 - 05:16:22 AM »
  No such thing as a stupid question when it can save you expensive damage, we all learn from others that is why this forum is so good, MOPAR people helping others.   :cheers:
