This is as far as I got last night. Trying to get an idea where everything will lay out before I start welding. the instructions are decent with the kit, but you are on your own as far as measurements. I will need to drill a 2 inch hole to mount the sway bat through the framerail on both sides. That is going to be tricky as it has to match up with the diff axels, go over the three link mount, but clear the floorpan, and line up with a second hole on the other framerail. They sent a template, but it is about worthless as it doesn't look to be to scale and won't match up to the framerail. I will end up having to make my own. I think I will go get some 2 inch PVC to mock it up inside the framerails and make sure it clears before drilling. Still have swaybar, panhard bar, and lower shock mounts to locate. So far it is looking pretty good. There have been quite a few issues with XV sending all the parts and the correct parts so it has been delaying the build. However they have taken care of everything so far, it just puts a frustrating delay in there to deal with. Good thing I am doing this myself, if I had this in a shop paying someone and we had a week delay because we had two left side widgets or was missing the muffler bearings I would be in trouble with them. Cars are hard to move out of the way with no suspension and you have everything tied down and level.
