Got the rear shocks, which happen to be exactly like the fronts, just different valving internally. If I had known or been told that it would have sped up the process a little. No pictures yet. got the shocks mounted and messing with ride height now to make sure it will all look right. I have tape on the floor and plumb bobs everywhere! it's looking like I will have about 7-8 inches from the ground to the bottom flat part of the rocker in front of the rear wheels. I am scrounging up some tires of the correct height to better visualize it. Little hard to work on the car during the week. 100 degree days here in Texas and when I get home at night and go to the shop it is like an oven in there. You can't weld or measure with a plumb bob with a fan blowing on you, so it gets uncomfortable up under a car real quick.
I did get a quote from prodigy on the brakes. 6 piston wilwood fronts, 4 piston rears, 13 inch rotors, polished master cylinder, internal parking brake, cables, lines, etc all for right at $4000. Probably won't find a better deal if I want to stick with the larger rotors. he said they installed the same set on Bill Howells charger with the Level II setup, so he knows it will work.
