quick pic of the clearancing on the body for the lower control arm. I don't know why the just didn't use a bar liek the air ride setup. The aluminum control arm looks cool, but is pretty tall and some trimming is required to clear. I currently have this one in the upper hole of the DR diff mount. The idea is for this lower bar to be level at ride height. Between this bar being level and the forced ride height of the shock setting you are pretty limited on where the axle will end up at. I can move this bar down one hole if needed and I have tried to give myself as much adjustment room as possible in the coilovers. I won't know 100% how the car will end up until I get tires, wheel, axles, etc. I also don't have years of experience building ground up suspensions or chassis setups so I am just going off what I read and think will work as far as trying to get it all set right.
