Author Topic: Removing a 3rd Member  (Read 18291 times)
Offline RDF
  • The pain that greets me is the stick that beats me
Re: Removing a 3rd Member
« Reply #75 on: February 29, 2008 - 06:50:10 PM »
Ah, for some reason i thought you'd have a 727 with a factory 360 car?
Well it's an original 318....I don't think the 360 was an option in 73, was it?
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
« Reply #76 on: February 29, 2008 - 07:18:54 PM »
Not on an E-Body... but other Mopar's it could be had.
Offline GoodysGotaCuda
« Reply #77 on: February 29, 2008 - 07:26:17 PM »
Ah for some reason it thought it was a factory 360 car. Yep, 904 it is
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline RDF
« Reply #78 on: February 29, 2008 - 07:50:56 PM »
Some auto stores show it as an option in 74, but not 73.  Everytime I go to Advance Auto I have to tell them it's a 74 for anything engine related.
Bob
1973 'Cuda
My build:
« Reply #79 on: February 29, 2008 - 08:11:12 PM »
exactly , the 360 was introduced in 74 in the E body but was available in other Mopars as early as 71 , mostly trucks & C body
Offline tactransman
« Reply #80 on: February 29, 2008 - 09:43:10 PM »
I knew it was a 904 because Robert and I kind of built it together. ;)
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #81 on: March 01, 2008 - 03:53:43 PM »
 :smilielol:  You got that right T.....thanks again for all those tips!
Ok, I got my pins in the mail today, but can someone tell me what I need to do with them again?  I'm a little foggy on how they go in and what keeps them in there, etc.  :clueless:
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #82 on: March 01, 2008 - 04:05:13 PM »
They go in,one in from each side,small dia. in first (just like Rob's pic)
The rivet goes in thru both and holds them in place till the axles go in. ( the axles actually bump up against the big heads on the pins)
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #83 on: March 01, 2008 - 04:12:23 PM »
Ok, mine came with a rod with each pin connected to the rod, so do I remove the rod and then place each pin in, or leave the pins connected to the rod and put the whole thing in as 1 unit?  :dunno:
Bob
1973 'Cuda
My build:
Offline RDF
« Reply #84 on: March 01, 2008 - 06:50:51 PM »
does anyone know the torque specs on the 10 bolts for the 3rd member?  I checked my manual, but didn't see anything....
Bob
1973 'Cuda
My build:
Offline ChallengerHK
« Reply #85 on: March 01, 2008 - 07:15:25 PM »
My 73 Service Manual says:
Carrier to axle housing bolt nuts - 45 ft/lbs
- Han Solo, Star Wars
Offline RDF
« Reply #86 on: March 01, 2008 - 07:29:14 PM »
BIG question....we're having difficulty (Goody and I) adjusting the end play...seems like whenever we tighten the axel bolts sligtly, we loose all end play.....my ? is.....is the rivet supposed to be put in the carrier with the pins?  or shold we have left it out?? :clueless:
Bob
1973 'Cuda
My build:
Offline RDF
« Reply #87 on: March 01, 2008 - 07:30:12 PM »
thanks a bunch ChallengerHK  :2thumbs:
Bob
1973 'Cuda
My build:
« Reply #88 on: March 01, 2008 - 07:35:02 PM »
The center pin in the sure grip I guess you installed all the way and tight, you had a non sure grip and 489 type in there prior. It was a square block. So it had a floater type. The axle was adjusted to that  other one before. So it sounds like you need to first install and tighten the non adjusting axle all the way, then, loosen the adjuster on the other axle , install it, tighten the 5 bolts, then adjust the end play.  Did I explain it good enough?
Offline RDF
« Reply #89 on: March 01, 2008 - 07:45:09 PM »
Yes...but we did that the first time and we lost all end play on the passenger side.....when we lossened the driver side, obviously we got some play back on the passenger side.......any other ides.....?? :clueless:
Bob
1973 'Cuda
My build:
