Author Topic: 318 - 440 engine swap. Engine wirng harness question  (Read 2304 times)
Offline Husker Cuda
« on: February 21, 2008 - 05:17:50 PM »
I am putting in a 440 in my 74 Cuda, originally a 318 car.  Can I buy a 70 or 71 engine harness from Year one and just plug it in to my bulkhead connector or do I need to buy a 74 wiring harness and modify it for the big block?   :clueless:
thanks
1974 'Cuda 512 stroker 650HP Indy heads, Hemi 4 speed, pistol grip - restored to new.
1970 GTX 440/727 Y4 Gold w/ black interior
1969 Camaro SS 396 4-speed X22
1970 Chevelle SS 396 - 375HP M22 4 speed
Re: 318 - 440 engine swap. Engine wirng harness question
« Reply #1 on: February 21, 2008 - 05:31:04 PM »
I'm thinking it's your latter choice. Maybe I'm off-base here, but the 70-71 big-block harness would assume a points style ignition system. I think you would just have to lenghten a few wires on the 74 harness to compensate for the distributor being in the front of the engine.   :dunno:
Offline matt63
« Reply #2 on: February 21, 2008 - 05:36:54 PM »
Sounds about right.  I think you can order repro harnesses with the electronic ignition update.
Matt in Edmonton
'68 Valiant
« Reply #3 on: February 21, 2008 - 06:51:00 PM »
I would just use the same wires. But un tape them to be sure they are not cracked and brittle from being baked on the side of the valve cover. The coil wires are about all that needs to be stretched. Oil sending units are in the back, water pump temp may have to add 6 inches maybe. alternator wires will fit, lengthen the electronic distributor wires or get the kit for 19 bucks and install that new. It is really easy.
Offline Husker Cuda
« Reply #4 on: February 21, 2008 - 07:55:15 PM »
great, thanks for all the input guys!
« Reply #5 on: February 21, 2008 - 09:41:20 PM »
Be aware that some of the wire changed position in the plug from year to year , you could order & 70 harness & just move a few wires around though
