Author Topic: quick -- 2 spd WIPER SWITCH questions  (Read 1786 times)
Offline AARudy
  • 1970 4-speed AAR---71 Cuda conv----70 Chall 440-6
« on: February 21, 2008 - 09:53:07 PM »
ok... this is my first time re-building a dash, so please bare with my questions....
A) is this the correct switch
B) the plug has a brown wire that does NOT line up when plugged in, it goes to an empty area...
C) is the black wire in the picture supposed to go on the wiper switch also?? (see pic)
D) thanks!!  :dunno: more questions to come also...
Offline 4Cruizn
  • HEMI FISH
Re: quick -- 2 spd WIPER SWITCH questions
« Reply #1 on: February 21, 2008 - 09:58:45 PM »
How many posts come off the back of that switch??  6 or 7?? :dunno:
Offline AARudy
« Reply #2 on: February 21, 2008 - 10:19:10 PM »
6 posts... the open one is where i thought that black wire goes...  but then that brown wire goes nowhere (no post)?? is that for a 3 speed?
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: February 21, 2008 - 10:46:20 PM »
I'm thinking that's a 2 speed switch.   :eek7:
Offline AARudy
« Reply #4 on: February 22, 2008 - 12:12:08 AM »
now i think that black wire goes to the small light bulb where my road lamp switch is....the switch panel light...it plugs right in there...
ALSO....I believe I need a 2 speed switch that controls the washer fluid...maybe I have the wrong switch....I did notice that that last pin has a stop on it so a plug can NOT be pushed on to it..??
« Last Edit: February 22, 2008 - 01:21:55 AM by AARudy »
Offline JayBee
« Reply #5 on: February 22, 2008 - 06:01:36 PM »
If you can read the letters on your switch this is how my 2 speed (6 post) wiper switch connects.
A - Red wire from grey connector
F2 - Green wire from grey connector
B/U - empty
P - Dark blue
B - Pink
H - Brown w/tracer
The solid brown wire in the black connector doesn't go anywhere
Your lone black wire, I'm not 100% sure yet.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline FY1Cuda
« Reply #6 on: February 23, 2008 - 11:01:39 AM »
That is a two-speed switch.  When you twist the shaft on the switch, you should get two clicks. The plug is for a variable speed switch (which has a prong near the center where that switch doesn't).  If you can find a variable speed switch and plug in the two connectors, you'll still have one prong empty on the back of the switch, but it should work fine.  I think the extra spade is for a ground, but the switch grounds on the mounting frame.
« Last Edit: February 23, 2008 - 11:11:57 AM by FY1Cuda »
Offline wally426ci
    • maryland mopars
« Reply #7 on: February 23, 2008 - 11:16:29 AM »
it looks like your grey plug needs to come off, then turn the large plug 90 degrees and it should line up with ALL of those pins.   :chatting:
does that make sense, just try it and take another picture.  :2thumbs:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Offline AARudy
« Reply #8 on: February 29, 2008 - 05:03:08 PM »
it is a two speed switch, BUT I figured out I need the switch that also will control the washer fluid....this switch does not...it wont push in at all....im going to a Mopar swap in Indianapolis tomorrow and maybe I can find one there...
« Reply #9 on: February 29, 2008 - 05:17:54 PM »
If you don't find one, give me a shout. The one in my car is a 2-speed with the electric washer option, but I'm in search of a variable speed switch that SHOULD have been in there in the first place.
Offline PlumCrazy
« Reply #10 on: February 29, 2008 - 05:47:45 PM »
Part number will tell you what speed switch it is.
