Author Topic: torsion bar removal  (Read 1589 times)
Offline kars440
torsion bar removal
« on: February 22, 2008 - 10:01:43 PM »
hi all, i have never removed torsion bars so i don't know how they come out. My car is a 74 challenger any help would be greatly appreciated thanks Karsten.
Re: torsion bar removal
« Reply #1 on: February 22, 2008 - 10:16:00 PM »
back off the T bar adjuster bolts , remove the clips behind the bars , undo the 15/16 nuts on the lower control arm pivots & the 3/4 " nuts on the rear of the struts & pry the lower control arm back until the T bars get loose enough the pull them out , make sure the weight is off the suspension when you back off the T bar adjusters
Offline kars440
« Reply #2 on: February 22, 2008 - 10:57:40 PM »
Thanks for the info  . Karsten
« Reply #3 on: February 22, 2008 - 11:24:52 PM »
you are welcome  :2thumbs:
Offline acudanut
« Reply #4 on: March 23, 2009 - 01:17:32 PM »
What are the t-bars and do you need any special tools.
Offline BacardiCBR
« Reply #5 on: March 23, 2009 - 05:30:36 PM »
t-bars = torsion bars
'70 AAR Tribute Car
« Reply #6 on: March 24, 2009 - 01:24:09 AM »
if you do this my way you need a 3/4 , 15/16 sockets & needle nose plier to remove the clip & a pry bar , nothing special required
Offline acudanut
« Reply #7 on: March 24, 2009 - 10:58:40 PM »
Okay, thanks.
