Author Topic: Breaking in engine with new tranny attached question  (Read 1195 times)
Offline AMXguy
« on: February 23, 2008 - 01:01:59 AM »
Next weekend I'm going to help my freind break in the 383 in his 70 Charger, in my 30 years wrenching on old cars I've never owned an auto transmission so I'm not sure what to do here. He had the engine and tranny both rebuilt so we're going to do the 20 minute break in thing on the engine but what do you do about the transmission fluid? the torque converter will suck up all the oil we can get in the transmission right off the bat won't it? so how do you deal with the transmission without shutting down the engine on break in? do you just add oil while it's running ?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Breaking in engine with new tranny attached question
« Reply #1 on: February 23, 2008 - 02:34:32 AM »
Fresh trans, start in neutral and add about 8 quarts while running.
« Reply #2 on: February 23, 2008 - 03:12:40 AM »
I would have at least 4 qts in before starting it then add after setting run speed , timing & mixture screws
Offline tactransman
« Reply #3 on: February 23, 2008 - 08:52:20 AM »
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #4 on: January 02, 2010 - 08:08:28 PM »
Reviving an old thread, as I am getting ready to do the same thing.  Do you fill the torque converter up before setting it in or just put it in dry and add fluid?  Probably fill it up about half full so that it does not spill out.  Approx. how many qts, dry, does a 727 hold?  Then after about a 100 mile break in, change the filter and fluid and should add about how many qts??  Feel like such a bonehead sometimes.  I could probably look in my manual when I get home in a week, but I am board at work and thought I would ask since I am sure that many of you have done it!  Thanks!
Jason
Offline BIGSHCLUNK
« Reply #5 on: January 02, 2010 - 10:36:02 PM »
Dry a 727 will take quite a bit... fill the converter first.
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
« Reply #6 on: January 02, 2010 - 11:53:05 PM »
approx 9 qts dry , put some in the converter first if possible but I doubt you will get a qt in there
Offline tactransman
« Reply #7 on: January 03, 2010 - 02:59:54 PM »
You do not HAVE to fill the converter first but it doesn't hurt to do it. Remember to start it up in NUETRAL !
Terry-tactransman
Union, Mo.
Offline mojavered
  • Someday!
« Reply #8 on: January 04, 2010 - 12:14:40 PM »
Why would you start it up in neutral?  Why not park?  This is going to be something that I need to remember somehow!
Jason
Offline tactransman
« Reply #9 on: January 04, 2010 - 12:23:11 PM »
If you start it up in park,you will get no fluid flow,no converter fill. (that is why you check the fluid in neutral) You could burn something up in the transmission.
Terry-tactransman
Union, Mo.
