Author Topic: OEM rear sway bar on lowered car?  (Read 4260 times)
Offline EvilTwinATX
Re: OEM rear sway bar on lowered car?
« Reply #15 on: February 26, 2008 - 10:29:21 PM »
keep us posted...
Offline miketyler
    • www.miketyler.net
« Reply #16 on: February 27, 2008 - 07:25:31 AM »
That's a good question. With a 2" drop, the stock bar will already have some deflection with the stock links. (think they are 3") Shorter links might be necessary to put the bar back in the neutral position for proper travel both ways on a lowered car. Maybe HP2 or CP will weigh in on this?   :clueless:
« Last Edit: February 28, 2008 - 11:30:21 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Katfish
  • 70 Challenger
« Reply #17 on: February 27, 2008 - 06:20:39 PM »
Sorry for that, I had to go thru a bunch of old related posts. It was Shelbydogg.
This looked like a great idea, but my sway bar mount doesn't have enough room to drill another hole.  It's pear shaped with the hole in the center.  The pic posted shows a square mounting area.  Was this something stock are fabbed?
« Reply #18 on: February 28, 2008 - 09:20:18 AM »
You do want to keep the bar in a more neuteral spot so it will have sufficient up and down travel when the suspension goes up and down. Depending on what you have in the same vicinity, you may need to shorten the links a little bit or a lot to allow the bar the same range of motion. A decent grade 5 or better bolt will do the trick.
