Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
A funny behaviour of a steeringbox
« previous
next »
Print
Pages:
1
2
Author
Topic: A funny behaviour of a steeringbox (Read 2889 times)
Belgium Cuda
Full Member
Living in Belgium but beeing Swedish
Re: A funny behaviour of a steeringbox
Reply #15 on:
February 27, 2008 - 02:04:12 PM »
No, just mark the top cover ( the threaded big cover towards the steeringwheel) before you remoove it so you get the same pressure on the
bearing you had before unless your steeringbox is worn mechanicly and not only leaking.
Logged
1970 Challenger Convertible - to become a Hemi tribute
1968 Charger R/T 500 cui stroker
LAA66
Sr. Member
Reply #16 on:
February 27, 2008 - 10:08:21 PM »
The mechanicals seem to be in good shape, just 38 year old seals. What technic or tool do you use to take the top cover off?
The pitman seal is leaking on mine also, is that more complicated?
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #17 on:
February 28, 2008 - 03:14:13 AM »
the pitman seal can be changed by removing the arm & replacing the seal
Logged
Belgium Cuda
Full Member
Reply #18 on:
February 28, 2008 - 06:02:18 AM »
Toolnames in english is sometimes not that easy but I used a large screwdriver and a hammer and carefully hit the openings in the
topcover teethsurounding ( was that correct???).
Logged
LAA66
Sr. Member
Reply #19 on:
February 28, 2008 - 11:10:26 AM »
I understand what you mean Belguim Cuda. I am pretty good with a hammer and punch.
Thanks Chryco, do you pry the old Pitman seal out with a screw driver or some other tool?
Logged
Belgium Cuda
Full Member
Reply #20 on:
February 28, 2008 - 04:46:46 PM »
Why not make 2 small holes in it and put 2 schrews in there and pull it out. Planned to do that on the top one before I decided to open it.
Logged
LAA66
Sr. Member
Reply #21 on:
February 28, 2008 - 10:01:12 PM »
Good idea, thanks. Smaller screws then the gap betwen the seal walls, maybe #6's.
Logged
Print
Pages:
1
2
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
