Author Topic: DrDiff rear disc conversion kit  (Read 2367 times)
Offline miketyler
    • www.miketyler.net
« on: February 24, 2008 - 08:31:15 PM »
I bought the DrDiff 11 3/4 disc conversion kit and started the install this weekend. Didnt get much accomplished outside of disassembly as it looks like I need new outer seals on my axle shafts. Good info on changing these BTW using ShelbyDoggs post here:
http://www.cuda-challenger.com/cc/index.php?topic=35471.0
Here's pics of the kit, as it ships. It's a high quality package, the brackets are made of .740 thk aluminum and are black andoized finish. These are his own design. The calipers are new, loaded from 94-04 Cobra. The rotor is open vane, 3/4 thk. I also bought the optional custom park brake cables. I'll post up pics as I install it. About all I got done was painting the calipers and cleaning up the axle housing, hubs, etc. Am considering making up new rear brake lines.
More to come
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: DrDiff rear disc conversion kit
« Reply #1 on: February 24, 2008 - 08:33:47 PM »
Looks good!  If you don't mind me asking, what was the cost?  Also, you may want to grind off the ford on the calipers, don't want to confuse your car any!
{oo/===\oo}
« Reply #2 on: February 25, 2008 - 01:33:56 AM »
the calipers look wide enough to intefere with the rear sway bar possibly
Offline miketyler
    • www.miketyler.net
« Reply #3 on: February 26, 2008 - 09:04:33 PM »
Cost of the kit was $600, the custom parking brake cables were optional at $100.
Quote
Maybe a good thing it hasnt sold yet, I may end up having to use that Hellwig bar yet.
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #4 on: February 27, 2008 - 07:25:45 PM »
Well after a crash course on rear axle rebuild 101 am ready to move forward with the disc conversion. May not get cranked back up on it till this weekend though.
new seals, reworked axle shafts with new brgs, seals, and 3" wheel studs, detailed calipers
« Last Edit: February 27, 2008 - 07:28:27 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline 422STROKER
  • Member Since 6/3/06
« Reply #5 on: February 27, 2008 - 07:29:30 PM »
Nice job, I wish my workbench looked like that.LOL
Tom
Tom
Offline gkring
« Reply #6 on: February 27, 2008 - 11:21:22 PM »
Tom
Look carefully, it's a Snapon box. Nice. Should have sanded off the Ford logo, but they look great.
Greg
1970 Barracuda driver
Offline 422STROKER
« Reply #7 on: February 28, 2008 - 05:50:31 PM »
I had to angle the  :chatting: screen to see it.LOL
My bench looks like this...
Tom
Tom
Offline miketyler
    • www.miketyler.net
« Reply #8 on: March 01, 2008 - 08:13:49 PM »
Axles rebuilt, and installed today. Set the end play, and mounted calipers. Mount bolts were a shad long, put a washer under the head, and clears. Put the wheel on for test fit, all good in the hood. Tomorrow I start working on the new lines and parking brake cables. As it is, I dont see this kit interfering with link end of the OEM sway bar.
72' Cuda restomod
70 Mustang Mach 1
« Reply #9 on: March 02, 2008 - 01:13:21 AM »
 :2thumbs:
Offline GoodysGotaCuda
« Reply #10 on: March 02, 2008 - 08:27:26 AM »
Lookin good mike, your 11 3/4" stuff leaves monday!
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Haney
« Reply #11 on: March 02, 2008 - 09:19:09 PM »
Mike,
Where did you get your wheel spacers?  Sorry for hijacking your thread with this question!!!!!
1969 Barracuda Coupe, 340, 4-speed
Offline miketyler
    • www.miketyler.net
« Reply #12 on: March 03, 2008 - 07:11:23 AM »
Got the flex line stays welded to the rear end, fabbed up new lines and ran em. Installed the e-brake cables. Getting closer.
Quote
Mike,
Dude - absolutely no problem, I got them from PepBoys
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #13 on: March 05, 2008 - 08:04:54 AM »
Got the brakes bled last night and no leaks! Nice to move thru a phase of the project with no issues!!   :cheers:
On a side note, not all el-cheapo double flaring tools are created the same. **  :nono:
I installed the kit parking brake cables, and then reconnected them to my existing parking brake cable system and have a new issue. Probably 6-8" too much slack. I have the nut all the way up on the threaded adjustment bolt. WTF? Does anyone have a diagram of the parking brake cable run on 71 and up Ebody? I need a reality check here.  :pullinghair:
** See also this thread for more detail on the budget double flair kit controversy:  http://www.cuda-challenger.com/cc/index.php?topic=43076.0
« Last Edit: March 05, 2008 - 08:17:51 AM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
« Reply #14 on: March 05, 2008 - 11:38:50 AM »
you need a good flare too , you cannot cut corners on a flare tool
 the intermediate cable is held by a hook to the front right of the trans crossmember maybe you can shorten the hook
