Author Topic: Rubber fuel line  (Read 5154 times)
Offline 71bigblock
    • Steve's Mopars
Rubber fuel line
« on: February 25, 2008 - 01:34:21 PM »
I want to run the rubber fuel line for my truck.  It has a 5.7 Hemi in it, so I need stuff approved for EFI.  I found this stuff on ebay a guy's got, looks pretty affordable.  I asked him if it is approved for EFI, he said he didnt know, but it says EFI on it.  In the one pic I can see it says EFI.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=120224716555&ssPageName=ADME:X:RTQ:MOTORS:1123
Sooooo, would I be safe using this stuff?  Thanks.   :swaying:
Re: Rubber fuel line
« Reply #1 on: February 25, 2008 - 06:05:19 PM »
You could pay that for 3" of the stuff.  :grinyes:
I say it's worth the gamble.
Offline 71bigblock
    • Steve's Mopars
« Reply #2 on: February 25, 2008 - 11:02:03 PM »
Yeah Mike, that EFI stuff is spendy.  The cheapest I found it around here is at Fleet Farm, at $2.59/foot for 5/16" line.  That would be a killer deal if I can use it.
Offline GoodysGotaCuda
« Reply #3 on: February 26, 2008 - 07:44:04 AM »
Are you trying to go from the tank with that huge roll of rubber line?  ???
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline airfueleddie
« Reply #4 on: February 26, 2008 - 08:00:48 AM »
Fuel Injection has 2 different pressure ratings. Throttle body had  around 14.5PSI, Multi-Point or PFI went to 35+PSI your Hemi needs at least this much. Is this rubber line rated for that?
« Reply #5 on: February 26, 2008 - 09:35:05 AM »
I would run steel tube most of the way & use High pressure FI line with double FI clamps to connect with
Offline 71bigblock
    • Steve's Mopars
« Reply #6 on: February 26, 2008 - 10:54:07 AM »
What do those double clamps look like CP?
I kinda planned on running rubber the whole way, I hate bending steel lines.  I dont want them to rust, either.  Stainless is too expensive.
What are the disadvantages of using rubber line?   ???
Not really sure, that's why I asked him.  I think I'm going to pass on that stuff, thanks.
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #7 on: February 26, 2008 - 11:06:42 AM »
That reminds me of a kid I went to automechanic school with.  He used like a spool and a half of fuel line going from the tank to the carb  :screwy: in his Caddy Fleetwood.  :roflsmiley:
The funniest thing is you could see the fuel line drooping under the car when he was finished, looked like someone hanging Christmas lights under there.  :roflsmiley: We were just waiting for him to catch the fuel line on something....  :faint:
« Reply #8 on: February 26, 2008 - 11:58:14 AM »
Please don't run rubber the whole way.    :eek7:
« Reply #9 on: February 26, 2008 - 12:07:46 PM »
I definately agree, its pretty tacky looking. Its not the safest thing given under the car can get hit with debris and rip the rubber line.  Stainless braided line is another story, plain rubber is cheaping out on the system, and not a good corner to cut. .02cents
1976 Dodge Warlock
Offline 71bigblock
    • Steve's Mopars
« Reply #10 on: February 26, 2008 - 01:15:09 PM »
Ok, I'll start pricing.  I would have done it right, fastened it right, etc.
But if you guys say so.  You all have much more experience than me in this stuff...
Thanks.   :swaying:
Offline wally426ci
    • maryland mopars
« Reply #11 on: February 26, 2008 - 04:20:39 PM »
Steve,
you can get your own metal line and bend it yourself. Get a flanging tool, and a bender. They're pretty cheap, and you can get creative. Think about the amount of time it would take that new metal to rust. I think you'll be safe. I bet most of us have the same 38 Year old metal lines under our cars, i know i do!  :cooldancing:
Oh, if you flare your own line, make sure you put the nut on first!!  :grinyes:
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
« Reply #12 on: February 28, 2008 - 02:44:42 AM »
the FI clamps do a full wrap on the line & are better for higher presser than the worm gear style
 Make Sure you use the double flare insert & put a bubble on the end of a steel line so the clamp cannot slide off the end of the tube
Offline mrob
« Reply #13 on: February 29, 2008 - 01:50:40 PM »
71bigblock,
If you don't like bending steel tubing, how about getting a roll of 5/16 or 3/8 aluminum tubing? You can bend that a lot easier than steel tubing and it's also a lot safer than running rubber hose from the tank to the carb. I've used aluminum tubing on a few cars and it's worked real well for me. Just a thought.
Offline ted
  • 74 cuda, 70 challenger r/t
« Reply #14 on: February 29, 2008 - 07:20:03 PM »
fuel injection rated hose always has the spec printed on it
