Author Topic: ball joints  (Read 1708 times)
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
ball joints
« on: December 26, 2001 - 09:45:18 AM »
71 Challenger
top ball joint
#%$*&(^%$ get the ^%#%$#@ ball joint out of the arm.
whoo- spent all morning trying to get them out- don't want to put heat to it.
any suggestions???
thanks-  John
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Re: ball joints
« Reply #1 on: December 26, 2001 - 10:02:12 AM »
I assume you are threading them NOT pressing them, do you have the socket?? trty hammering them to shock the threads loose & lots of penetrating fluid .
Offline ted
  • 74 cuda, 70 challenger r/t
Re: ball joints
« Reply #2 on: December 26, 2001 - 06:21:52 PM »
if so he has trashed control arm.
Offline 71 DEPUTY
    • Cardomain
Re: ball joints
« Reply #3 on: December 27, 2001 - 07:53:33 AM »
I'VE TRIED TO TWIST THEN OUT- NO LUCK- TALKED TO A LOCAL SHOP- THEY WILL REMOVE AND REINSTALL THEM FOR ME.
THANKS FOR THE INPUT GUYS
JOHN
Offline 70 chally
Re: ball joints
« Reply #4 on: December 28, 2001 - 08:07:45 PM »
I think the tool your looking for is called a 10pd. sledge?
Your ball joints will go right in if you use this tool the right way! ;D
Honest i'm not making this stuff up!! ;)
LEAD OR GET RUN OFF THE ROAD
                70 Challenger
Offline Dark Horse
  • 70 Cuda ,69Mach 1,70 Charger RT/SE
Re: ball joints
« Reply #5 on: January 14, 2002 - 11:41:17 PM »
dude those upper ball joints can be a *****..3/4 drive big pipe get a couple buddies and heave away...serious..oh and have some cold beers ready, you'll need those..lots
When you see the Dark Horse...take heed
hell is coming to breakfast......
Offline 71 DEPUTY
    • Cardomain
Re: ball joints
« Reply #6 on: January 15, 2002 - 04:58:55 PM »
thanks guys- got the local shop to TWIST them out with some heat- they had fun doing it.
I didn't need beer-- just Crown Royal-- hic---lol
thanks again guys for the tips
