Author Topic: Carrier Help, quick please.....  (Read 920 times)
Offline RDF
« on: February 27, 2008 - 01:23:29 PM »
I've got a 489 case with an open carrier and 2.76 gears in it.  I recently bought a 741 case with a suregrip (clutch style) carrier and 3.23's in it.  I took it to a shop to have the carriers swaped and a new set of 3.91's put in it.  I just got a call from the guy and he said the bearing kit that I gave him was way too big for the carrier.  :clueless:
So my question is: are all carriers interchangable, regardless of what case they came out of?
Did I order the wrong kit from summit?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=RMG%2D8310311&N=700+0&autoview=sku
I need help with this asap as the guy has my pig all apart and is wondering what I want to do with it.
Thanks!!!   :2thumbs:
Bob
1973 'Cuda
My build:
Offline 73Chally
Re: Carrier Help, quick please.....
« Reply #1 on: February 27, 2008 - 01:41:42 PM »
Please don't take offense if this is a stupid question, but is your plan to put the posi unit into the 489 case, or rebuild the 741?  I am assuming you are re-using the 489.  With that said, are you sure the 3.91 gear set is for the correct carrier?
Offline RDF
« Reply #2 on: February 27, 2008 - 01:46:43 PM »
You're correct....I'm rebuilding my 489 with the posi unit from the 741.  The 3.91 gear set is for a 489 case.
I just got off the phone with Mopar Performance (1.888.528.4364) and they said all carriers are interchangable.  The Race bearings may be different for each carrier though....so he said I will probably need the race bearings for a 741 case for that suregrip to fit in my 489 case.   :faint:  I had NO idea about this..... :banghead:
Bob
1973 'Cuda
My build:
Offline RDF
« Reply #3 on: February 27, 2008 - 02:13:04 PM »
The guy ran some numbers on the carrier that I have and turns out that it's from a 65-68.....which I'm most positive won't work in my case.... :faint:
He also said the nut that came off the pinion gear originally is too small for the new set of gears I bought!!  :faint:  do they just sell the nuts for the pinion gears???
Bob
1973 'Cuda
My build:
Offline ntstlgl1970
  • T a c o c a t
« Reply #4 on: February 27, 2008 - 03:07:04 PM »
I had the same problem with the pinion nut on another build I did, are there any 4x4 or diff shops in your area? they should be able to get (or have on hand) a pinion nut
Offline RDF
« Reply #5 on: February 27, 2008 - 03:11:30 PM »
there are a couple of 4x4 shops that I can call......ugh.....I had no idea this many things could go wrong.....I'll have to call and see if any of them have one....biggest problem is, I don't know what size the nut is.... :clueless:
Bob
1973 'Cuda
My build:
