Author Topic: Does anyone have a carrier?  (Read 3002 times)
Offline RDF
  • The pain that greets me is the stick that beats me
« on: February 27, 2008 - 02:16:00 PM »
I could really use a suregrip carrier for a 73 cuda....does anyone have one they are willing to sell?  I need it asap....
Bob
1973 'Cuda
If we never drown we'll never know how well it tastes....So tell me how it tastes and I'll know just how well you drowned.
My build:
http://www.cuda-challenger.com/cc/index.php?topic=45749.0
Offline ntstlgl1970
  • T a c o c a t
Re: Does anyone have a carrier?
« Reply #1 on: February 27, 2008 - 02:26:15 PM »
I was going to respond on your other thread, is the OD of the 741 case early bearing cup a different diameter than the 489 case? I would think you could run the early case bearings and you would be good to go unless the bearing cup OD is different between the cases. Check here:
http://www.timken.com/en-us/products/Pages/Catalogs.aspx
the 489 case takes a LM104949 cup and the 741 takes a 25590 cup according to the application guide
Offline RDF
« Reply #2 on: February 27, 2008 - 02:30:31 PM »
unfortunately, I have no idea.....the 489 case is at the shop and the 741 is at my house...what do you mean by OD?
Bob
1973 'Cuda
My build:
Offline ntstlgl1970
  • T a c o c a t
« Reply #3 on: February 27, 2008 - 03:04:52 PM »
I'll just post the specs I found, the OD is the outer diameter of the cup (the part the diff bearing rides in that sits in the diff case bore)
These specs are from the timken website: the 741 bearing cup OD is .005" bigger than the 489 cup OD. Whether this is a problem or not I would ask chryco or your shop. They would need to measure to figure out how much interference fit (ID of diff case bearing bore vs. OD of bearing cup race diameter) there is when the caps are torqued.
Offline RDF
« Reply #4 on: February 27, 2008 - 03:13:01 PM »
thanks for the specs.....I called the guy and he said he ran these numbers c30847 and it came back as a 65-68 year.....I don't know where he ran those numbers at, but he's going to try to order a bearing kit for a 741 case and see if that has the correct bearings he needs.  :faint:
Bob
1973 'Cuda
My build:
Offline ntstlgl1970
  • T a c o c a t
« Reply #5 on: February 27, 2008 - 03:15:17 PM »
I looked and the early carrier bearings are stocked at autozone (I used a zip code for orlando 32809, not sure if near you)
http://www.autozone.com/selectedZip,32809/initialAction,partTypeResultSet/initialN,11201713/initialNtt,/initialNo,/shopping/selectZip.htm
you could look at autozone.com I used 67 polara 383 for the car. They show the same part numbers I found in the timken application guide.
Offline tactransman
« Reply #6 on: February 27, 2008 - 04:18:12 PM »
This is showing the 741's and 742's as using the same.
http://www.moparts.com/Tech/Archive/axle/7.html
You should be able to get the right bearings and use the diff you have.
Terry-tactransman
Union, Mo.
Offline RDF
« Reply #7 on: February 27, 2008 - 04:41:37 PM »
I called Mopar Performance back and they directed me to DTS (TimKen I believe) and they told me ALL carriers are interchangable, regardless of the year.  Now he said I may have an earlier style carrier that uses different bearings, so they gave me the 2 bearings part numbers (25590 & 25520, 2 of each) and those can be bought at ANY parts store.  So those are on their way to the shop and my pig should be ready tomorrow, hopefully.  Cross your fingers on this one....I'd hate to have to buy a whole new carrier because I got the wrong one... :faint:
Bob
1973 'Cuda
My build:
Offline tactransman
« Reply #8 on: February 27, 2008 - 04:48:48 PM »
I think you'll be fine now. When you get it back in the car, it will be all worth it and you will be pleasantly surprised! :woohoo:
Terry-tactransman
Union, Mo.
« Reply #9 on: February 27, 2008 - 09:19:21 PM »
If it dont work out, I will give you a carrier (489) if you need it.
« Reply #10 on: February 28, 2008 - 03:18:03 AM »
I have a spare carrier as well , I think it is a 742 though
Offline RDF
« Reply #11 on: February 28, 2008 - 08:55:22 AM »
Thanks Moparal and Chryco....I'm waiting to hear from him this morning....and hoping it's good news.  I'll keep you guys posted....:2thumbs:
Bob
1973 'Cuda
My build:
Offline kmyles
« Reply #12 on: August 13, 2009 - 01:00:55 PM »
Sorry to dig up such an old post but I am wondering what the c-30847 represents? I have an opportunity to purchase what he calls a sure grip and the only numbers he can find are the ones I mentioned above. Is it a sure grip? If so is a cone or clutch? PPLLLeeease Help! I want a SG for the chally!!
Thx :2thumbs:
_________
Kevin
Mopar Lover....Cuda's....Challengers Rule!!!!
- 1951 Dodge - 2 door hardtop (Sold!!)
- 1971 Dodge Challenger
- 2012 Dodge Challenger Yellowjacket
Hard to believe what 20 years will do!!!!
Offline tactransman
Terry-tactransman
Union, Mo.
Offline kmyles
« Reply #14 on: August 13, 2009 - 01:45:24 PM »
_________
Kevin
