Author Topic: Will E body big block battery cables work on a small block.  (Read 1444 times)
Offline HemiOrange70
« on: February 29, 2008 - 04:57:07 PM »
The part numbers are different but I would think they should interchange no problem. Any thoughts?
Thanks
Re: Will E body big block battery cables work on a small block.
« Reply #1 on: February 29, 2008 - 05:41:02 PM »
They'll work just fine
« Reply #2 on: February 29, 2008 - 05:50:49 PM »
Obviously the ends of both are the same, but are big-block cables longer?  :dunno:  This is something I always wondered about too.  :grinyes:
« Reply #3 on: February 29, 2008 - 06:12:53 PM »
MR Mike, or should I say Master tech Mike. I read you were filling in for Chryco right now, so you have to be more positive. You got the negative right :roflsmiley:  They are longer and will work. Starter to the battery is very close to the same and the neg should be a bit longer.
« Reply #4 on: February 29, 2008 - 06:24:12 PM »
Thanks Al,   :wave:
  As long as the big block cables are longer, he won't have a problem.
