Max tire size for E-body Cuda
Author Topic: Max tire size for E-body Cuda  (Read 3753 times)
Offline johnhuckin
  • 73 'Cuda
    • John Huckin's 73 Cuda
« on: February 29, 2008 - 06:00:49 PM »
Hi all. I realize the rim size issue has been thrown around alot but I was wondering if anyone has fit 31x12.50R-15 Hoosier Pro Street Radials under the back end of an E-body Cuda using Dr. Diff's offsets and a B-body rear? And if so, what wheel and what B/S?    :dunno:
Offline Rare_T_A
    • Freiss Family Mopar Site
Re: Max tire size for E-body Cuda
« Reply #1 on: February 29, 2008 - 06:36:04 PM »
I have the stock 8 3/4 rear with 275X60X15 on it. There is a little more room to go though.
'09 Challenger R/T  5.7 HEMI Auto
'70Challenger T/A 340 727
Fargo, N. Dak.
My web Site:  http://freiss.co.nr
My Flikr Page: http://www.flickr.com/photos/102813164@N04/
I was born with nothing and I still have most of it left!
Offline GoodysGotaCuda
« Reply #2 on: February 29, 2008 - 06:37:32 PM »
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline Carlwalski
« Reply #3 on: February 29, 2008 - 09:37:13 PM »
The Hoosiers will fit if you relocate the springs and get the correct BS, perhaps B-Body rear? Dr Diff can custom make your diff to any size so you could mock everything up then order one to be safe. The Hoosiers have a 12.5 (315mm) You'll have a 1.5" room to play with as most if not all E-Bodies have around 14" section width (+/-).
I plan to run a set of Mickey Thompson Sportsman S/R Radials when I want good traction and performance on longer trips. They will replace my daily driving 275/60 BFGs which are more for looks, photos and lower speeds. Mickey Thompson Sportsman S/R tyres are 305mm, 28” OD @ 12.10 SW so stacks of room as I will also be running an XV L2 rear suspension 3 link kit.
:2cents: :cheers:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline johnhuckin
  • 73 'Cuda
« Reply #4 on: February 29, 2008 - 10:02:00 PM »
Not sure what tire your talking about but the specs from the Hoosier site is:
# Pro Street Radial Tire Size: 31x12.50R-15LT
# Appr. Rim Widths: 8.5-11"(10")
# Overall Dia.:  31.0"
# Section Width: 13.4"
# Tread Width: 10.3"
# Max. Load: 1520 Lbs.
# Rated Infl.: 25 PSI
# Speed Rating: 95H
# Weight: 39 Lbs.
Section width is 13.4" so that's gotta be really tight.
Offline Carlwalski
« Reply #5 on: March 01, 2008 - 03:16:50 AM »
Sorry, my bad, I had them confused for the Sportsmans.
In that case, they won't fit. If they do you won't be able to drive with them. Best of luck with it.......
nivvy
« Reply #6 on: March 01, 2008 - 07:45:15 AM »
# Speed Rating: 95H
# Weight: 39 Lbs.
no good........... also too tall imo ..... cut down on the tire height choice to get more "tread width" ......... need 1/2 room minumum on each side of the tire for flex :2cents:
Go wth the mt sportsman if you want a radial type tire.... 28*12.5*15  this 1st photos wason 5" backspace an 8.5 rim... would recomend 10" rim... 3/4 relo kit and b body rear.....
The yellow challenger is my car...
8 3/4 rear - 3/4 relo kit - 28*12.5 et street car is lowered 2.5"s - no wheel spacers.... - 5" backspace  - b body rear --- I know its a challenger but 360cuda here uses the same setup with a 295/50 tire......  pm 360cuda .......  :2thumbs:
even though the pic dont show it I can go up one more size  :bigsmile:
« Last Edit: March 01, 2008 - 09:10:10 AM by StRoKer »
Offline johnhuckin
  • 73 'Cuda
« Reply #7 on: March 01, 2008 - 10:05:10 AM »
StRoKer - Thanks for the pics!  Cars look great!   :2thumbs:
I think I'm gonna try 29/12.50/15 Hoosier Pro street tires with Dr. Diffs B-body rearend stuff.
My next question is does anyone use Torque Thrust D's with 5" BS?  I know they will need to be special ordered.
Thanks, again, for all the great comments.   :thumbsup:
