Author Topic: Time To pull out the Dash...  (Read 3670 times)
Offline JayBee
Re: Time To pull out the Dash...
« Reply #15 on: March 02, 2008 - 07:15:38 PM »
I did mine like Mike did (frame stayed in) just last November. It wasn't that hard, 11 speed nuts and the 2 outer screw. I did find it easier to remove my bucket seats(they need new backs anyway) so I could contort under the dash and get at all the nuts.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline gkring
« Reply #16 on: March 02, 2008 - 07:48:50 PM »
Just make sure you take your Vin tag off the dash before you send it, they will not refit this for you.  So you will have to get some rosette rivets aswell.
I heard somewhere to drill or cut the rivets out from the backside, then just glue the plate and rivets back in place on the new dash. Saves you from having to buy "correct" rivets. I wish I had heard or thought of that before taking mine out. Aren't the correct style rivets pretty expensive?
Also-take the whole dash out, it's not that bad.
Greg
1970 Barracuda driver
« Reply #17 on: March 02, 2008 - 09:01:09 PM »
This is just personal preferance but I feel it makes sense.
When you put the new one back on...the mounting dash to frame. Leave the one's in the middle not as tight. Let the dash have some flex in the middle so that it can expand and contract to heat and cold.
Many years ago I cinched a nice down all around and it didn't take long for it to crack.
Offline HemiOrange70
« Reply #18 on: March 02, 2008 - 09:40:22 PM »
I drilled my VIN tag rivets out from the bottom and I am going to use them again, but I will have to glue them in. You can buy two factory rivets for 35 for a pair of use regular rivets and grind the sides flat
Offline gkring
« Reply #19 on: April 07, 2008 - 12:16:19 AM »
Having just spent the weekend putting one in I double vote for taking the whole asembly out. You will need to do much trimming and "adjusting" on the pad to get it to fit nice. Much easier to do that outside the car on a bench than trying to test fit in the car.
Greg
Offline 472 R/T SE
« Reply #20 on: April 09, 2008 - 12:12:27 AM »
Just ordered mine from Nick Sunday.  Did you have to yank the windshield?
HELP SUPPORT THE REGISTRIES because all cars matter.
I like to sleep For I'm walking in my dreams.
Live life like every DAY is your last!
Offline gkring
« Reply #21 on: April 09, 2008 - 12:32:33 AM »
Nah, swivel, long extension, and a 7/16 deep 1/4 drive socket was pefect for getting to the bolts in the defroster vents. I really see no reason to pull the windshield. Stuff some rags in the defroster vents before trying to put those bolts back in, however. Don't want to drop one down the defroster vents.
Greg
Offline buzzard
  • Why is their AIR
« Reply #22 on: April 16, 2008 - 10:57:53 PM »
 I've done them both ways. I would only do it again, taking the dash out. Use a loooong philips on the vent screws [Snap-On]  Caver the L-R sides where the pivot bolts are so you don't scratch the paint taking it out. Build a 2 by 4 stand to hold it from the pivot points to work on. It works well and gravity is on your side. Good luck
