Author Topic: Jacking it up a Bit  (Read 1001 times)
Offline patrick
Jacking it up a Bit
« on: March 03, 2008 - 12:50:18 AM »
 I would like a little bit of lift in the rear end. Not a lot, just a little. My 73 Challenger is a Performence model, with factory sway bar's, front and back. It corner's better than the wife's new Mazda. How much performance handling will I lose, if I switch out those KYB's in the rear, and put in some Air-Shock's.  Thank's, Pat
Columbia Gorge 340 Rallye Dude
Offline Carlwalski
Re: Jacking it up a Bit
« Reply #1 on: March 03, 2008 - 12:57:02 AM »
You could just re-tension the leaf springs? I did and it's a lot better in handling, looks (IMO) and traction.
Just another idea. :2cents: :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #2 on: March 03, 2008 - 01:10:01 AM »
Do not use air shocks they kill the handling & hurt the chassis of the car , add an extra leaf or rearc or replace the springs both air shocks & long shackles are the wrong way to do it
Offline GoodysGotaCuda
« Reply #3 on: March 03, 2008 - 12:26:34 PM »
handling will severely suffer from air shocks.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline drewcrane
« Reply #4 on: March 03, 2008 - 08:39:21 PM »
 :iagree: air shocks ssssssssssssssssssssssssssssssssssssuck try some adjustable shocks, carrera ,or koni, or a comparable brand :2thumbs:
Offline vinb
« Reply #5 on: March 03, 2008 - 08:56:30 PM »
Why do they even make air-shocks. Not good ride,  terrible and it will break the welds on the shock crossmember sooner or later...
Re-arc the springs and a good adjustable shock will do the trick...
« Reply #6 on: March 03, 2008 - 09:01:07 PM »
same reason why they make the 'tornado'. people will buy them. lol.
1976 Dodge Warlock
Offline LAA66
« Reply #7 on: March 03, 2008 - 09:36:32 PM »
 Air shocks were originally to stabilize pickup trucks when carrying a load. Later, everyone wanted to jack up their ride so the manufacturers added muscle cars to the line.
