Author Topic: 4 Prong Balast  (Read 3158 times)
Offline CUDA JAS
  • vroooooom!
4 Prong Balast
« on: March 03, 2008 - 10:55:20 AM »
Is there correct way to install a 4 prong ballast resistor?
I know one side is for start and one is for run, but which is which?
Jas
74 'cuda 360/727
Just call me a gearhead!
Re: 4 Prong Balast
« Reply #1 on: March 03, 2008 - 12:05:07 PM »
there is different resisance on both sides of the ballast , 1 side is for the coil & 1 is for the ign ECU , the factory plugs were made so thay could not be reversed , , I assume you have added the ECU so if it the new ECU has only 4 pins not 5 then the dual resister is not used anyway , just use the 2 pin type for the coil
Offline CUDA JAS
  • vroooooom!
Re: 4 Prong Balast
« Reply #2 on: March 03, 2008 - 02:28:17 PM »
Thanks CP...
I am acutally rebuilding the exisitng wireing harness, and I have no confidence that the ballast was mounted or wired correctly.
Jas
74 'cuda 360/727
Re: 4 Prong Balast
« Reply #3 on: March 03, 2008 - 02:31:54 PM »
I would need a wiring diagram to figure out how it is wired , I believe the lower resisatnce is the coil so the blue one end & brown to the coil on the other end
Offline CUDA JAS
  • vroooooom!
Re: 4 Prong Balast
« Reply #4 on: March 03, 2008 - 03:14:53 PM »
Sorry I shoudl have been more clear in my question.
Is there a top and bottom, as opposed to side to side.
Should the green wire (with red tracer) from the ECU go to the top or bottom of the ballast (does it matter).
I just have a feelign that mine is not right.  When I pulled the coil off, the tach lead (aftermarket) was hooked to the positive side of the coil.   When I look at the wireing diagram, the lead that was on the positive terminal should have been on the negative. It worked and the car ran, but I know that is not correct.
I am so confused...I just want to hook it al up right and have it run!!!!!
74 'cuda 360/727
Re: 4 Prong Balast
« Reply #5 on: March 03, 2008 - 03:19:06 PM »
the ballast can be mounted either way up so top & bottom means nothing , the plugs should have a tab that fits into the xlot in the ballast to orient it , both plugs will have the tab on it & orients the plug the same way at either end of the ballast os no it doesn`t matter which plug goes to which end of the ballast
Offline wally426ci
    • maryland mopars
Re: 4 Prong Balast
« Reply #6 on: March 03, 2008 - 04:49:35 PM »
Does anyone repro the 4 prong connector?
{OOI====I====IOO}
      '71 Challenger
      [O[]=====[]O]
      '68 D100
Re: 4 Prong Balast
« Reply #7 on: March 03, 2008 - 05:10:46 PM »
If you have an ohm meter, I can help you. According to my Haynes manual, the side of the resistor that goes to the coil and ignition switch is .5 ohms. The side that goes to pin 1 and 3 of the ECU connector is 5 ohms.
This is a crappy pic, but the top one is for you...
Offline CUDA JAS
  • vroooooom!
Re: 4 Prong Balast
« Reply #8 on: March 03, 2008 - 09:00:24 PM »
cool thanks guys.
I do have an ohm meter, so I will check it out!
Charger Specialties has the terminal covers.
Linky - http://www.chargerspecialties.com/catalog.htm
74 'cuda 360/727
