Author Topic: 741 Case  (Read 1539 times)
nivvy
741 Case
« on: February 25, 2004 - 10:03:26 AM »
I am going to be changing the gears in the rear end....but does the case matter..like if i buy 3.91 with a 489 case will it bolt right up to my exsisting rear end that has a 741 case...?
thx
Offline RAD1229
  • 72 Challenger
Re:741 Case
« Reply #1 on: February 25, 2004 - 10:17:41 AM »
I am almost positive that all 8 3/4 cases will bolt to the housing with no problems.  i know that I have changed 741 and 742 out with no probs.  From what I have read and understand is if the diameter is same the bolt patterns will be too!  Good Luck!
-RAD
1972 Challenger
Re:741 Case
« Reply #2 on: February 25, 2004 - 09:13:18 PM »
the 741 , 742 , 489 will al swap into the same housing
