Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Blinker problem
« previous
next »
Print
Pages: [
1
Author
Topic: Blinker problem (Read 1897 times)
Tim440RT
Jr. Member
Get an R/T
Blinker problem
on:
February 25, 2004 - 07:31:53 PM »
Ok, my friends car, you turn on the blinker, and the light comes on, but doesn't blink. Anybody have any ideas.
Logged
1970 Challenger R/T 440
Wheels
Jr. Member
Re:Blinker problem
Reply #1 on:
February 25, 2004 - 08:00:23 PM »
Check the bulbs first, on some cars a burned out bulb will make the blinker flash twice as fast because of lower resistance or not at all. Otherwise its just a bad flasher unit. Mine will blink real slow sometimes and its either the flasher or low voltage. The flasher is under the dash.. dont remember exactly where...
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re:Blinker problem
Reply #2 on:
February 25, 2004 - 08:52:44 PM »
2 flashers , one is attached to the ashtray , I think this is the one you are after , trhe hazard one is near the steering column
Logged
MEK-Dangerfield
C-C.com Expert
I don't get NO respect! Member since 1/25/2002
Re:Blinker problem
Reply #3 on:
February 26, 2004 - 04:33:06 AM »
My first thought is a burned out bulb somewhere. If not the bulb, then possibly a bad ground with one of the lights.
Logged
2016 SXT+. 1 of 524 SXT+'s in Plumb-crazy for 2016.
lime 70
Jr. Member
Tires that turn together burn together
Re:Blinker problem
Reply #4 on:
March 11, 2004 - 10:56:42 AM »
If all your lamps work it defintly the flasher I had a 71 Newport that would go through one every couple of months but it was my daily driver my challenger has got the same amount of lamps as the Newport had but I havent had any problems yet. You should use a heavy duty flasher.
Logged
70 Challenger 440 SIX PACK
budrinker
Full Member
Re:Blinker problem
Reply #5 on:
March 11, 2004 - 08:43:15 PM »
could be you are low on blinker fluid
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re:Blinker problem
Reply #6 on:
March 12, 2004 - 12:08:16 AM »
that stuff is so expensive !!!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Blinker problem
