Be Cool Radiator
Author Topic: Be Cool Radiator  (Read 2022 times)
Offline Madmax440
Be Cool Radiator
« on: April 01, 2008 - 11:14:39 PM »
Just received my Be Cool radiator today and there are no brackets on the side to mount it in the car ??? Does anybody else have a Be Cool Radiator ??? And if so - How in the hell did you go about mounting or did yours come with brackets ??? It sure is purty though and YES I KNOW THAT -  :useless:
Offline Madmax440
Re: Be Cool Radiator
« Reply #1 on: April 01, 2008 - 11:22:30 PM »
I see that there was another thread on this asking for pictures which would certainly help, but the pictures from that one are long gone.
nivvy
« Reply #2 on: April 01, 2008 - 11:27:56 PM »
I have a be cool setup..... do you have pics of yours... Ill take some pictures after work.
« Last Edit: April 02, 2008 - 05:27:37 AM by StRoKer »
nivvy
« Reply #3 on: April 02, 2008 - 03:52:00 PM »
 :picture: I will be making my own top brackets... see generic photoshop pic....
« Last Edit: April 02, 2008 - 03:54:11 PM by StRoKer »
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #4 on: April 02, 2008 - 04:05:22 PM »
I think the radiator I got from them is a different one.  Mine had small tabs welded to it, much like the ones StRoKer has.  However,  I had to cut the aluminum top bracket that was supplied with it, to fit.   I will try and grab a picture and post it.
nivvy
« Reply #5 on: April 02, 2008 - 05:07:09 PM »
I had to cut my top bracket as well..... as you can see in the pics.... just gonna make other ones...
Offline Madmax440
« Reply #6 on: April 02, 2008 - 05:52:45 PM »
Wow this makes me feel much better - That is exactly what I got. I was expecting the brackets to be on the side from top to bottom. I was looking at those brackets and wondering what the hell am I going to do with this. I SEE said the Blind Man.
Offline Madmax440
« Reply #7 on: April 02, 2008 - 07:32:29 PM »
I think that I am going to want to have mine sit up a little higher, almost even with the cross bar of the radiator support. Eiether have to shim it up at the bottom or have those cleats moved down. Will have to do something different with that brace at the top as will.
Offline thedodgeboys
  • ''Normal’s Overrated''
    • THE DODGE BOYS
« Reply #8 on: April 02, 2008 - 08:12:54 PM »
Looks like the classic chevy style  :faint:
I had side brackets put on my radiator to fit the factory holes.
I would show ya a picture but it was only 3 weeks ago. :rofl:
Go Fast & Have Fun...
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #9 on: April 02, 2008 - 10:38:36 PM »
looks just like the one I put in a Customer Hemi runner, the way the fans fasten to the rad is a little cheesy if you ask me. I wish they used the factory mounting points in the core support.
2013 Tige' RZR 343hp
nivvy
« Reply #10 on: April 03, 2008 - 12:31:11 AM »
 :2thumbs:
Offline Madmax440
« Reply #11 on: April 03, 2008 - 07:36:23 PM »
Stroker, Let me know what you come up with on the top bracket. What would you recommend as far as raising it up maybe 3 1/2 inches ??? I can either find someone that can wel aluminum to lower those cleats on the side or shim it up from so that the mounting point is higher.
nivvy
« Reply #12 on: April 03, 2008 - 07:40:37 PM »
It is a real tight fit ... the back of those fans are real close to the pumps....... I actually grinded mine a little.... had alittle more clearance with the aftermarket powersteering pump.... the back of your nice shromy fans may be not as bulky as mine... or it could be worse  :eek7:
nivvy
« Reply #13 on: April 03, 2008 - 07:49:24 PM »
 :picture: I might have put a little bigger belt in also to get the pump away from the fan.... however the factory style pump is right up on th fan.... like a 1/16 right up on... could put blocks under it and lift it up if it will clear... would need longer bolts to fasten into the plug you have to put into the frame.....
« Last Edit: April 03, 2008 - 07:51:03 PM by StRoKer »
Offline cudagirl4406pk
    • Garageartmusclecars
« Reply #14 on: April 04, 2008 - 10:24:49 AM »
Mad max440 contact my husband i have a becool rad setup in my cuda i am only 45 min from baltimore and 25 min from belair you can come up and look at my 71 cuda with it in it for references and we have someone to help you with the special brackets if you need them.Call his cell phone at 410-713-8895-kenny he can elabrate more for you.He is off work today and all weekend.
just tell him i gave you the number.
michele
