Author Topic: Anyone know anything about B-Body K frames?  (Read 955 times)
Offline jeryst
« on: April 02, 2008 - 10:37:56 AM »
I know a lot of members have B-Boy cars, so I figured I'd ask.
I have a 70 Charger that came with a 318. I'm planning on putting a 383/727 in it.
What do I need to do that? Will the original K-frame work? Do I need new mounts?
Offline Oldschool
  • Member Since 9-05-06
Re: Anyone know anything about B-Body K frames?
« Reply #1 on: April 02, 2008 - 10:59:06 AM »
I am pretty sure the K-frame is the same.  Not sure about the mounts though I am thinking they used a different mount...    :bigshades:
Ken  --  In Georgia
« Reply #2 on: April 02, 2008 - 11:33:40 AM »
the K frame is the same , you will need different engine mounts available at Schumakers
Offline jeryst
« Reply #3 on: April 02, 2008 - 02:39:05 PM »
If the K frame is the same, why can't I just use regular Mopar mounts for a big block?
Offline Challenger6pak
« Reply #4 on: April 02, 2008 - 02:50:43 PM »
You can use the original Mopar BB mounts.  Chryco was just letting you know where you could get them if you need them.
« Reply #5 on: April 02, 2008 - 06:50:50 PM »
Exactly , the factory mounts work ifyou have a set if not Schumakers ahs them
Offline jeryst
« Reply #6 on: April 02, 2008 - 07:10:37 PM »
Okay. Thanks guys.
Offline jeryst
« Reply #7 on: April 02, 2008 - 07:31:53 PM »
Okay, now I'm starting to get confused. I looked on eBay to see what I could find.
Some people are saying that the mounts are the same for big block and small block.
Others are selling "Big block" mounts, but the ones some people are selling are different from ones that others are selling. Some look like they have rubber on the, some don't.
Can anyone post a pic of real big block motor mounts?
Can I just go to an auto parts store and buy a set?
« Reply #8 on: April 02, 2008 - 07:54:58 PM »
The rubber pads are the same.  On one side the steel part is the same for small blcok and big block.  I don't remember what side w/o going and looking.  I can't right now.  Someone may know.  The steel part is different on one side.  You could get one mount from Sherman.  Here are pics of the BB mounts. These will also show how to bolt the mounts to the block.
« Last Edit: April 02, 2008 - 07:57:22 PM by Challenger6pak »
« Reply #9 on: April 02, 2008 - 07:58:24 PM »
the rubber monut block was the same for some years 66-72 approx the steel bracket on the block is definatly different between small & big block
« Reply #10 on: April 02, 2008 - 09:02:01 PM »
Here are some mounts listed on the board.
http://www.cuda-challenger.com/cc/index.php?topic=43537.0
Offline 69bronzeT5
  • SRT Guru
  • Mopar or No Car
    • Forgotten Mopars
« Reply #11 on: April 02, 2008 - 09:34:57 PM »
Yes, the original k-frame will work. My 69 was a 318 and I put a 383/727 in it exactly like you plan on doing. Everything fits fine. I would get a bigger rear end in it though. Chances are you have a 8 1/4 in it...you should alteast have a 8 3/4 with a big block engine.
Associate Editor for Mopar Connection Magazine
http://moparconnectionmagazine.com/
1969 Charger
1970 Coronet
1971 Charger R/T
1971 Road Runner
1989 VW Cabriolet
2004 SRT-4
2006 Grand Cherokee SRT8
2008 Challenger SRT8
2016 Wrangler Unlimited
2017 Ram 1500 Rebel
